Visibility in drawings environment
kresh.bell
kresh.bell
i have an iLogic for drawing environment, i want that when i run it, all the part with prefix "-" in solidbody name be hidden.
Sub Main()
    Dim view As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select view")
    Dim assembly As AssemblyDocument = view.ReferencedDocumentDescriptor.ReferencedDocument
    For Each occ As ComponentOccurrence In assembly.ComponentDefinition.Occurrences
        Dim occDoc As Document = occ.Definition.Document
        If (occDoc.DocumentType = DocumentTypeEnum.kPartDocumentObject) Then
            Dim partDoc As PartDocument = occDoc
            Dim name As String = partDoc.ComponentDefinition.SurfaceBodies.Item(1).Name
            If (name.StartsWith("-")) Then
                hideOccurence(view, occ)
            End If
        End If
    Next
End Sub
1) It doesn't work when those parts with prefix "-" are parts of assembly, is it possible to fix it?
2) it would be even better if it is possible to make iLogic in such a way that it in the drawing environment in the tree, controls "Visibility"
now, iLogic controls the visibility lines in the drawing area, not in the tree
dutt.thakar
@kresh.bell
Are you looking for something like this? I have added few lines, in the code which will search for the part documents inside the assembly, and if they start with "-", It will hide them.
Sub Main()
			If occ.Name.StartsWith("-") Then
				 view.SetVisibility(occ,False)
			End If
            End If
        End If
    Next
End Sub
See if that works, if you need something more or different, please try to explain it in more detail.
If this answer has solved your problem please ACCEPT SOLUTION and hit like if you found it helpful..!
Dutt Thakar
LinkedIn
kresh.bell
unfortunately, something is not ok
dutt.thakar
@kresh.bell
The line that is giving error is not modified by me.
hideOccurrence is the same as it was in the code you initially posted, I think when you have copied the iLogic rule from the forum or from anywhere else, there must be a function/sub that is doing this operation.
I only added these lines in the existing code.
	End If
If you still struggle to find something, revert here and I will see what I can do.
Dutt Thakar
LinkedIn
kresh.bell
something is wrong, still the same error
dutt.thakar
@kresh.bell
Try below code and see if that helps.
Sub Main()
			End If
			Dim obj As Object = partDoc.ComponentDefinition.SurfaceBodies.Item(1)
                view.SetVisibility(obj,False)
            End If
        End If
    Next
End Sub
Dutt Thakar
LinkedIn
WCrihfield
It's not really clear which of these you are trying to do:
- if component's name starts with "-" then turn it's visibility off
- if SurfaceBody's Name starts with "-" then just turn the visibility of that SurfaceBody off, but leave its component visible
- if component's first SurfaceBody's Name starts with "-" then turn the component's visibility off (but do nothing with the SurfaceBody)
If that SurfaceBody is the only SurfaceBody within the Part, then simply turning that SurfaceBody's visibility off should be enough.  Or if you simply turn the component's visibility off, that should be enough.  But turning both off seems like 'overkill'.
Here's a code that: 1) doesn't check the name of the component; 2) if the component is a Part, check if its first SurfaceBody's name starts with "-"; 3) if it does, try to turn that component's visibility off within the view; 4) if that fails, let you know.
Sub Main()
    Dim oView As DrawingView = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kDrawingViewFilter, "Select view")
	If oView Is Nothing Then Exit Sub
	Dim oADoc As AssemblyDocument
	If oView.ReferencedDocumentDescriptor.ReferencedDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
		oADoc = oView.ReferencedDocumentDescriptor.ReferencedDocument
	End If
	Dim oPDoc As PartDocument
	For Each oOcc As ComponentOccurrence In oADoc.ComponentDefinition.Occurrences
		If oOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
            oPDoc = oOcc.Definition.Document
		End If
		If oPDoc.ComponentDefinition.SurfaceBodies.Item(1).Name.StartsWith("-") Then
			Try
				oView.SetVisibility(oOcc, False)
			Catch
				MsgBox("Failed while attempting to turn off visibility of component '" & oOcc.Name & "', within this view.",,"")
			End Try
		End If
    Next
End Sub
Other things to consider:
Does the DrawingView have a View Representation (other than "Master" set)?  If so, is the checkbox checked for "Associative"?  If 'Associative' is turned on, it likely won't let you change visibility of stuff within the view.  You may have to turn 'Associative' off before attempting to modify visibility of items within the view.
Do you have a 'Level of Detail' representation or a Position representation set for that DrawingView?
If this solved your problem, or answered your question, please click ACCEPT SOLUTION.
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
