VbScript to Open Inventor And Change Project Options
MechMachineMan
Advisor Advisor
MechMachineMan
Hi there.
Looking for some quick help!
I want to write a vbscript or some quick executable that achieve the following goals.
1) Open a new instance of inventor
2) In this new instance, change the project to a predefined one and activate it.
3) Change where my application options point to content center.
Why:
a)I have been doing a lot of tweaking to content center in my spare time, and to keep it from affecting our production, I am doing it in a set of working files before I push it to the server files.
Every break, I constantly have to manually perform the steps above which is tedious and annoying.
b) I feel like vbscript is quite a powerful tool to have in my repertoire if it can perform this functionality.
c) I haven't found a way to be able to run a rule in inventor that switches the active project, esp. seeing as you need all documents close to switch a project.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
MechMachineMan
Well, I did it!
Steps to make it work.
1) Open a new notepad file
2) Paste this code
Set InvApp = CreateObject("Inventor.Application")
InvApp.Visible = True
InvApp.ContentCenterOptions.SetAccessOption 81153, "C:\Users\Owner\Desktop\CC Library Editting"
Set oProject = InvApp.DesignProjectManager.DesignProjects.ItemByName("C:\Users\Owner\Desktop\CC Library Editting\CC Library Editting.ipj")
oProject.Activate
InvApp.Documents.Open "C:\Users\Owner\Desktop\recessed rubber bumper.ipt", True
3) Save file as .vbs
4) Run the .vbs
5) Profit!
Justin K
