VBnet mass
VBnet mass
VBnet mass
Is there anyway via ilogic or VBnet(Or anything possible) to set the mass of  1 body of multybody part to zero???
bradeneuropeArthur
Sure.
Dim oDoc As AssemblyDocument
    oDoc = _InvApplication.ActiveDocument
    Dim oAssDef As ComponentDefinition
    oAssDef = oDoc.ComponentDefinition
    Dim oMassProperties As MassProperties
    oMassProperties = oAssDef.MassProperties
    oMassProperties.Mass ="0"
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
JelteDeJong
I tested the following code. but on further investigation, I discovered that this looks very promising but in fact, it sets the mass property of the complete part...
Dim doc As PartDocument = ThisDoc.Document
Dim def As PartComponentDefinition = doc.ComponentDefinition
Dim body As SurfaceBody = def.SurfaceBodies.Item(1)
Dim bodyDef As PartComponentDefinition = body.ComponentDefinition
Dim mass As MassProperties = bodyDef.MassProperties
mass.Volume = 1
Also, I found this topic. Here someone wants to get the value (not set it). The Autodesk employee confirms that there is no direct way to get the value. He proposes some alternative ways to get the value but I guess it will not help you set the values. I came to the conclusion that it's not possible to set the mass of a solid body.
Jelte de Jong
Blog: hjalte.nl - github.com
I konw there is no way with ilogic or VBA. But i am wondering is there a way in VB.net (Like if you want to make an add-in)? I know it's more complicated. I don't want to start learning making add-ins if i don't know if i can set one body mass  of multibodypart to zero??????
JelteDeJong
When you write iLogic rules you are writing vb.net code. To interact with Inventor by code in an add-in you need to use the same API as the API you have access to in iLogic. Therefore there is no difference between what you can do with iLogic and an add-in. (I have to note that there are some things that are very hard to do by iLogic rule. Like reacting to events.) So in your case creating an add-in will not help you.
Jelte de Jong
WCrihfield
Just a passing thought, but if you really need to eliminate the calculation of mass from one separate body in a multi-body part, you may need to convert that body to a surface, instead of a solid, one way or another.  It might be possible to do by code if that sounds like a plan that would work for your situation.
Wesley Crihfield
(Not an Autodesk Employee)
It's a great idea but sadly it doesn't help in my case. Maybe a way to check the changed body mass or changed body volume would help in my case?? If i can't change it via ilogic, than i want to in some way check If the changed body mass(or body volume is zeri). Is this maybe possible???
