VBA to Break Link to Table
waynehelley
waynehelley
I have a VBA code which picks out an assembly to use as a template dependant on the users selections in a user form.
The problem is that the assemblys were created using iAssemblies, so they are member files and hence are linked to the table and unedittable until the link to the table has been broken,
Is there any VBA code to do this autonomously??
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
YuhanZhang
You can open the iAssembly member document and then use below VBA code sample to break the link:
Sub BreakLinkToFactorySample()
    Dim oDoc As AssemblyDocument
    Set oDoc = ThisApplication.ActiveDocument
    If oDoc.ComponentDefinition.IsiAssemblyMember Then
        oDoc.ComponentDefinition.iAssemblyMember.BreakLinkToFactory
End Sub
If this solves the problem please click ACCEPT SOLUTION so other people can find it easily.
Rocky Zhang
Inventor API PD
Manufacturing Solutions
Autodesk, Inc.
