iLogic button / system for allowing a user to add a parameter
bmerton
bmerton
I am in the process of implementing Configurator 360. I am looking for a feature/ logic that would allow for my user to add additional parameters.
We make sheet metal enclosures. Our customers want to incorporate cut-outs (holes) on different surfaces of the enclosure. There is no way of predicting the number of these holes they require (it could be 1, it could be 200).
The holes are either round, square, oblong, rectangular.
It is easy to define and control a single hole or even multiple holes using iLogic. However, if you don't know the eventual number of holes they will require, then it would be better if there was some feature that allowed the user to add a parameter / feature based on iLogic rules from the interface.
I hope this is clear and thanks so much for any / all help in advance. This is my first post!
LukeDavenport
Hi Bmerton.
Take a look at iFeatures for this. You can add them programmatically in the required positions on your part.
