VBA syntax error on "replace" function (replace character in string)
j_steenbergen
Message 1 of 9
j_steenbergen
I have a string in which I'd like to replace commas with a dot. Normally in VBA you would use:
Dim s As String
s = "15,6kg"
s = Replace(s, ",", ".")
Except that I get a syntax error on the replace function. Pretty weird, because it is listed as function in the Inventor VBA object browser. Auto correct also makes the r from replace lower case so it somehow doesn't recognize it.
It seems with iLogic a similar syntax is working:
https://forums.autodesk.com/t5/inventor-customization/ilogic-rule-replace-character-in-string/m-p/48...
So am I doing something wron or is this a bug?
Replies (8)
Message 2 of 9
bradeneuropeArthur
Are you using this in I-logic or in VBA?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 9
j_steenbergen
I'm using VBA (see title)
Message 4 of 9
bradeneuropeArthur
Than use this:
Public Sub main()
Dim s As String
s = "15,6kg"
s = VBA.Replace(s, ",", ".")
MsgBox s
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 9
j_steenbergen
Wow, that did the trick. Thanks!
Message 6 of 9
TobFischer94
... and how would it be possible in iLogic?
Nevermind, i found out, the following text did the trick for me. In my example, "param" is the numeric value with a comma, and "Variable" is the string that gets converted with a period
Variable = param
Variable = Replace(Variable, ",", ".")
Message 7 of 9
bradeneuropeArthur
Public Sub main
Dim st As String = "aba"
st = Replace(st,"b","c")
MsgBox (st)
End Sub
Public Sub main()
Dim s As String
s = "15,6kg"
MsgBox s
End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 9
maxim.teleguz
this right here is what i have been searching for the last 5 years.
Message 9 of 9
maxim.teleguz
you can shorten it like so:
Public Sub main
Dim st As String = Replace(st,"b","c")
MsgBox (st) End Sub
or my code and how i used it:
a = 'pass on your string here from your code
Dim TXT2Find As String = "Precision='2'"
Dim NewTXT As String = "Precision='3'"
If a Like NewTXT Then
MsgBox("nothing changed")
Exit Sub
Else
a = Replace(a, TXT2Find, NewTXT)
