VBA Suppress / Unsuppress drawing view
Jacques.Grobler
Message 1 of 11
Jacques.Grobler
Hi all
I have a drawing that has to suppress / unsuppress a view as the model changes. How can I do this with VBA?
Replies (10)
Message 2 of 11
mwighton
You can write a rule that will supress/unsuppress the view using If_Else statements.
Did this post help out? Hope it did.
If so please use the 'Accept as Solution' or 'Kudos' Button below.
God Bless
Mwighton
Message 3 of 11
Jacques.Grobler
Hi mwighton
That is what I am trying to do in VBA however I have no idea of where to start
Message 4 of 11
mwighton
The way I would do it, is...
Create a parameter in your model that will change based on when you want the view to be present or not.
Link that parameter to your drawing.
Create the rule that will suppress/unsuppress the view.
If you can attach the model and drawing file so I can take a look I would be happy to help. Also tell me which view is the one that would be suppressed and when.
God Bless
Mwighton
Message 5 of 11
Jacques.Grobler
All I am looking for is the piece of code that says:
If modelstate = true then
Drawing.view (5).visible = true 'help with this line pls
Else
Drawing.view (5).visible = false
End if
Message 6 of 11
mwighton
You can try reading This.
God Bless
Mwighton
Message 7 of 11
Jacques.Grobler
This is for rules in iLogic, I specifically need it for VBA pls
Message 8 of 11
MechMachineMan
From the link posted above:
{code}
Sub Main()
FindView("VIEW2").Suppressed = True
End Sub
Function FindView(viewName As String) as DrawingView
Dim doc As DrawingDocument = ThisDoc.Document
For Each view as DrawingView in doc.ActiveSheet.DrawingViews
If (view.Name = viewName) Then
Return view
Next
Throw New ArgumentException(" No view named " & viewName & " was found")
End Function
{code}
Use the basics from that with this:
and you have a working program! Yay!
DrawingView.Suppressed Property DrawingView.Suppressed() As Boolean
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 9 of 11
Jacques.Grobler
Hi Guys
I am still not getting this code to work. Can someone please assist me?
Message 10 of 11
MechMachineMan
Where you stuck at? And this is almost definitely gonna take learning on your part to figure out which Feature will cause the view suppression to occur, unless you just have a manual parameter or something...
Justin K
Message 11 of 11
Jacques.Grobler
And after a bit of a struggle< I finally got the code right
Thanks for all the help guys
Sub viewDrawing_Toggle(viewName As String, boolStatus)
    Dim drgDoc As DrawingDocument
    Set drgDoc = ThisApplication.ActiveDocument
    Dim drg As DrawingViews
    Set drg = drgDoc.ActiveSheet.DrawingViews
    Dim drgView As DrawingView
    Set drgView = drg(viewName)
    drgView.Suppressed = Not boolStatus
End Sub
