VBA remove items on sketch
Hello, I create by VBA some points by using following code snipe:
Dim oSketch As PlanarSketch
Set oSketch = ThisApplication.ActiveEditObject
Dim oPoint As Point2d
Dim dblX As Double
Dim dblY As Double
' [...] define dblX and dblY
Set oPoint = ThisApplication.TransientGeometry.CreatePoint2d(CDbl(dblX), CDbl(dblY))
oSketch.SketchPoints.Add oPoint, True
Now I want to create a foreach loop to delete all points.
Maybe some one has a code snipe for this? Thanks a lot!
Sergio.D.Suárez
Hi, with this macro code you can erase all the points of the sketch that you identify through the item, I hope you serve some segment of the program for your particular case. regards!
Sub Delete_All_Points()
Dim doc As PartDocument
Set doc = ThisApplication.ActiveDocument
'Define planar sketch
Set oSketch = doc.ComponentDefinition.Sketches.Item(1) 'Specify the sketch through the item
'Get a reference to the SketchPoint collection.
Dim oPoints As Inventor.SketchPoints
Set oPoints = oSketch.SketchPoints
For Each oPoint In oPoints
oPoint.Delete
Next
End Sub
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
@Anonymous: Thank you for your code!
I tryed it and get a "Run-time Error: '5': Invalid procedure call or argument" on line oPoint.Delete
So I checked the number of points:
'oPoint.Delete ' Run-time Error: '5': Invalid procedure call or argument
i = i + 1
Next oPoint
MsgBox (i)
This MsgBox show the right quantity of my points. So far it works, but will not delete.
Do you have a idea? big thx!
Sergio.D.Suárez
Try these lines maybe pass the problem and can be identified, I have tried it in my file and I do not see an error. I will be attentive to your answer. regards
   On Error Resume Next
   Call oPoint.Delete
Next
End Sub
Mechanical Designer
Thats it! You made my day!
