i-Logic import .dll error
Jef_E
Message 1 of 1
Jef_E
I have a "successful" working Add-In installed on  10 machines at our office. And now I would like to expose the AddIn power a little further by making it available in iLogic to the user, so they can do "Difficult" tasks using a small call in iLogic (no real programming knowledge required).
To do this I use following code block ( sample program )
AddReference "C:\ProgramData\MyAddin\Assembly\MyAddin.dll"
AddReference "Autodesk.Inventor.Interop.dll"
Imports Inventor
Imports MyAddin
Sub Main
	Dim oInteropModules As New MyAddin.InteropModules
	Dim oType As HeadTypeEnum = DirectCast([Enum].Parse(GetType(HeadTypeEnum), Type), HeadTypeEnum)
	r = oInteropModules.CalcSmallRadius(oType, ID, Thickness)
	R = oInteropModules.CalcLargeRadius(oType, ID, Thickness)
	ThisApplication.ActiveDocument.update2
End Sub
And this works well, on 9 of the 10 user machines.
On one machine I get the following error,
Error in rule: UPDATE_VALUES, in document: Part1
Could not load type 'XpressTools.InteropModules' from assembly 'XpressTools, Version=1.0.6711.18973, Culture=neutral, PublicKeyToken=null'.
What can I do to fix this error? I already tried to uninstall and re-install Inventor.
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Replies (0)
