Message 1 of 9
Hi all. I'm interested in how to get to the method of these commands in VBA. Thanks for any help
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
This is clear to me. I want to use this command in my macro. how can I apply it in VBA code? Is it possible to show an example?
Yes I know.
But I need to know where the original command is located, then I can help your further!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
FYI: I believe that is one of the selection methods.
The online help for this can be found under the "Select Command Reference" topic.
https://help.autodesk.com/view/INVNTOR/2024/ENU/?guid=GUID-3E3537A9-565E-4F2E-B69D-069EDCDF1AE1
There is usually a selection filter type drop-down in the Quick Access toolbar with something in its list labeled "Select Component Offset...". I'm not familiar with it either.
Wesley Crihfield
(Not an Autodesk Employee)
Yes, this is the same method. Everything I found in the selection priorities. But I don’t see anything suitable or am I missing something?
It is an internal Command: AssemblyEnhSelComponentBBCmd
The Spherical Select is: AssemblyEnhSelSphereCmd
Both require user action.
Don't know if it's possible to program any input.
Call ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyEnhSelComponentBBCmd").Execute
Thank you very much. I tried searching among the commands but couldn't find it. And now you rubbed my nose in) Now I’ll try to work with this, thank you very much.
