VBA Forms - how do I distribute?
sam
Message 1 of 13
sam
Hi Everyone,
With help of this wonderful community I have been able to learn a lot in last couple of months, though still a long way to go.
I have created a VBA that creates custom parts as per given selections and inputs of button and then it assembles them in an assembly and later it creates drawing for each part. I have read various posts (& AU classes) on subject of VBA and Add-ins and I understand that distribution of VBA is not easy. My question is, whether is there any possibility to run this form through button on tool bar or may be through a Macro?
Any reply or reference to help material will really be appreciated.
PS. I am trying hard to get Visual Studio installed but it definitely take long to get a reply for that.
Best regards,
sam
Accepted solutions (3)
Replies (12)
Message 2 of 13
bradeneuropeArthur
Can you store your VBA project on shared network drive?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 13
sam
@bradeneuropeArthur Yes, I guess that could be done. How would that help?
Message 4 of 13
bradeneuropeArthur
Because all users use the same project within inventor then.
If you change something, this will be available directly to all users!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 13
sam
@bradeneuropeArthur Thanks for that - that I guess will solve the problem partly. Any suggestion/help for this part in my OP.
Best regards,
sam
Message 6 of 13
bradeneuropeArthur
Please ask what you need and i will guide you through...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 13
bradeneuropeArthur
You can add macro-buttons yes!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 13
sam
Sure - Lets suppose that everyone has access to the project through shared drive as suggested by you.
Now - whenever I need to access this form I to VBA Editor and press (F5) Run UserForm to see the form. Is there any way that a user could shoot this off from an icon on tool bar (or anything  else to avoid opening VBA editor)
best regards,
sam
Message 9 of 13
sam
@bradeneuropeArthur Thanks. Please consider that I don't know really much (though I have foolishly claimed in OP that I have learned a lot).. So you mean I can call this form through macro and macro can be activated through a button on tool bar? Would you mind elaborating this in little detail (whenever possible for you).
best regards,
sam
Message 10 of 13
bradeneuropeArthur
you need to add a bitmap with the same name as the module to the folder with the vba modules.
keep reading for details
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 13
bradeneuropeArthur
like this:
https://forums.autodesk.com/t5/inventor-customization/no-customicon-to-vba-macro-button/td-p/9061649
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 13
bradeneuropeArthur
use a single module to show your form, like:
You can now add this module to the ribbon of inventor:
Hope this explains.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 13
sam
@bradeneuropeArthur Thank you so much for patiently explaining this to me. I will keep on digging more resources (and links you provided).
best regards,
sam
