VBA Command manager not excecuting
nicholas_provo
nicholas_provo
Hey guys
I'm trying to add automatically bend tables to the flat patterns of metal sheets following this code below.
I also want the right BEND ID's on the drawing view. To do that you need to select the table and the view which needs the ID's and then force trough the command manager to add the ID's to the drawing.
Got it from the following topic:
https://forums.autodesk.com/t5/inventor-customization/bend-tags-to-view-add-tags-to-view/td-p/513977...
The function does everything correclty;
*it places the bend table, with the correct columns
*it also selects the table
*it also selects the right view to add the BEND ID to
But when I excecute the command "DrawingTableSelectBendViewCtxCmd" nothing happens.
I even checked the command with the EventWatcher program and it checks out.
Anyone have a clue what is going wrong? Working currently with INV2018.3
Many thanks!
Function Add_BendTable(ByRef oDrawingView As DrawingView, ByRef oModel As Document, ByRef oSheet As Sheet, ByRef oDrawingDoc As DrawingDocument)
Dim oPoint As Point2d
Dim oBendTable As CustomTable
Set oPoint = ThisApplication.TransientGeometry.CreatePoint2d(15, 15) ' ISO View (or current view)
If oModel.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
MsgBox ("A sheet metal document must be open.")
Exit Function
Dim strColumns(1 To 4) As String
strColumns(1) = "BEND ID"
strColumns(2) = "BEND DIRECTION"
strColumns(3) = "BEND ANGLE"
strColumns(4) = "BEND RADIUS"
On Error GoTo ExitFunction
Set oBendTable = oSheet.CustomTables.AddBendTable(oModel.FullDocumentName, oPoint, "Bend Table", strColumns)
Dim oCtrlDef As ControlDefinition
oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("DrawingTableSelectBendViewCtxCmd")
oDrawingDoc.SelectSet.Clear
oDrawingDoc.SelectSet.Select oBendTable
oDrawingDoc.SelectSet.Select oDrawingView
oCtrlDef.Execute
ExitFunction:
End Function
bradeneuropeArthur
Could you upload the complete code you are using?
The code where you declare:
oModel As Document,
oSheet As Sheet,
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
nicholas_provo
Arthur
I exported the VBA code for you and added inventor Test files, should work stand alone.
I added into the attachment.
If you want to run the code stand alone on a unfolded sheet metal use this:
Just make a command button on a new forum sheet.
Thanks!
Private Sub CommandButton1_Click()
Dim oDrawingDoc As DrawingDocument
Set oDrawingDoc = ThisApplication.ActiveDocument
Dim oSheet As Sheet
Set oSheet = oDrawingDoc.ActiveSheet
Dim oDrawingView As DrawingView
Set oDrawingView = oSheet.DrawingViews.Item(1)
Dim oModel As PartDocument
Set oModel = oDrawingView.ReferencedDocumentDescriptor.ReferencedDocument
Exit Sub
'On Error GoTo Exitsub1
Set oCtrlDef = ThisApplication.CommandManager.ControlDefinitions.Item("DrawingTableSelectBendViewCtxCmd")
oCtrlDef.Execute
'Exitsub1:
End Sub
bradeneuropeArthur
This is my result!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
nicholas_provo
Arthur
Correct, it's the same what is happening to me. But not quite yet the result we want.
You have to excute this on the 'Flat Pattern' of the metal sheet.
The result of the code should that the 'Bend ID' will be shown. On the flat pattern.
If you do it manually, you can create the same bend table:
Annotate/Table/General Table. You can see that Bend ID Displaying on the flat pattern.
When you use the code, it will force the same thing, but nothing happens with the bend ID.
The code below will select both views and force the Bend ID to be displayed on the flat pattern.
But when executing "DrawingTableSelectBendViewCtxCmd" nothing will happen.
"DrawingTableSelectBendViewCtxCmd" is the command code when you manually select the views, press right mouse button and select "Add Tags to View"
oDrawingDoc.SelectSet.Select oSheet.DrawingViews.Item(1)
Call oCtrlDef.Execute
I'll attach 2 screenshots with the results.
grt
Nicholas
