Vba code to get file vault history latest version, and check if local file is the latest version
engilic
engilic
Hi
is it possible to get vault file history latest version, number, and / or to check if user has and is using the latest local file.
the file is vba macro file, forgot the extension, sorry.
thx
bradeneuropeArthur
Sure. I will have a look earliest Monday.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
Something similar to this?
https://forums.autodesk.com/t5/inventor-ilogic-and-vb-net-forum/vault-lifecycle-state-of-model-throu...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
engilic
Thank you @bradeneuropeArthur.
 I will say same as you did, I will check it on Monday.
engilic
@bradeneuropeArthur
Unfortunately, this is for the life cycle, I would like to get this:
Latest released Version and Checked out Version.
Actually the most important is to know whether the user has the latest released version, the one that is not checked out, and then to ask them to update. One more time this is not for model files this is for Macro file ***.ivb.
thx
