VBA code to change sketch's Dimensions
fujitranthanh
fujitranthanh
I have a simple code to resize sketch.
But it doesn't work with diameter and radius
Hope everyone can help me
Thanks and regards
Sub test()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oDim As Object
On Error Resume Next
Set selSet = oDoc.SelectSet
Dim constraint As DimensionConstraint
For Each constraint In selSet
'MsgBox constraint.Parameter.Expression
constraint.Parameter.Expression = 100
constraint.Driven = True
constraint.Driven = False
Next
End Sub
Dev_rim
When you are working with the expressions you have to give a string with unit of measure. For example:
"100 mm"
"15 in"
Its only can be edited like this:
  If TypeOf constraint Is DimensionConstraint Then
            Dim param As Parameter
            Set param = constraint.Parameter
            Select Case constraint.Type
                Case kDiameterDimConstraint, kRadiusDimConstraint
                    param.Expression = "50 mm"
                Case Else
                    ' Set for linear or other types
                    param.Expression = "100 mm"
            End Select
        Else
            MsgBox "Selected item is not a dimension constraint."
If my answer is solved your problem, please mark it as Solution
Freundliche Grüße / Kind Regards
