Dimension Arrangement with Ilogic - Stacking of Linear Dimensions
drafting4KGWTN
drafting4KGWTN
Hi all, long time lurker - 1st time poster
I've been experimenting with Ilogic code since i started with my new company, and from the forums on here i've mashed together bits and pieces to arrange dimensions (exclusive of angular) how we need for detailing (we don't really use chain or baseline and only ordinate sometimes). But lately I'm coming across an issue that I'd like to sort out.
current resultcurrent result
desired resultdesired result
The 1st pic is showing what i get currently with the code I'm using, the 2nd pic is showing what I want to achieve.
please see below for code:-
' Set a reference to the active drawing document
Dim oDrawDoc As DrawingDocument
oDrawDoc = ThisApplication.ActiveDocument
' Get the collection of dimensions on the active sheet.
Dim oDimensions As DrawingDimensions
oDimensions = oDrawDoc.ActiveSheet.DrawingDimensions
Dim oDrawDim As DrawingDimension
' Iterate over all dimensions in the drawing and
' center them if they are linear or angular.
For Each oDrawDim In oDimensions
    If TypeOf oDrawDim Is LinearGeneralDimension Then
Next
' Get a reference to the select set and clear it.
Dim oSelectSet As SelectSet
oSelectSet = oDrawDoc.SelectSet
oSelectSet.Clear
' Add each dimension to the select set to select them.
	    oSelectSet.Select(oDrawDim)
Next
' Get the CommandManager object.
Dim oCommandMgr As CommandManager
oCommandMgr = ThisApplication.CommandManager
' Get control definition for the arrange dimensions command.
Dim oControlDef As ControlDefinition
 oControlDef = oCommandMgr.ControlDefinitions.Item("DrawingArrangeDimensionsCmd")
' Execute the command.
Call oControlDef.Execute
Not really well-versed in this yet, so any help would be appreciated
(apologies if this is in the wrong section or previously addressed)
marcin_otręba
maybe try to use arrange method :
Dim dimensions As ObjectCollection = g_inventorApplication.TransientObjects.CreateObjectCollection
For Each drawDim  As DrawingDimension In odraw.ActiveSheet.DrawingDimensions
    drawDim.CenterText()
    Call dimensions.Add(drawDim)
Next
Call odraw.ActiveSheet.DrawingDimensions.Arrange(dimensions)
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
drafting4KGWTN
no love from that one mate, throwing up this error
jnowel
Try this.
I do have additional layers for other dimensions to create some sort of exclusion (since I'm selecting all dimensions on current sheet)
Dimension Off-Center = Those I don't want to be centered anymore, but want to be "Arranged"
Dimension Off-Center + Aligned = Those not to be centered nor arranged
Dimension Aligned = Those to be centered but not "Arranged"
Sub Main
	'On Error Resume Next
	Dim oDoc As Document = ThisApplication.ActiveDocument
	If Not oDoc.DocumentType = kDrawingDocumentObject Then Exit Sub
	Dim oSheet As Sheet = oDoc.ActiveSheet
	Dim oView As DrawingView
    Dim oDrawingDim As DrawingDimension
    Dim oDrawingDims As DrawingDimensions
    Dim oDimsToBeArranged As ObjectCollection
	'For Each oSheet As Sheet In oDoc.Sheets
	    oDrawingDimensions = oSheet.DrawingDimensions
	    oDimsToBeArranged = ThisApplication.TransientObjects.CreateObjectCollection
		For Each oDrawingDim In oDrawingDimensions
			If TypeOf oDrawingDim Is LinearGeneralDimension Then
				If Not (oDrawingDim.Layer.Name = "Dimension Off Center" Or  oDrawingDim.Layer.Name = "Dimension Off Center + Aligned") Then
					'Only center those not indicated as off-center
					oDrawingDim.CenterText
				If Not (oDrawingDim.Layer.Name = "Dimension Aligned" Or oDrawingDim.Layer.Name = "Dimension Off Center + Aligned") Then
					oDimsToBeArranged.Add(oDrawingDim)
			ElseIf TypeOf oDrawingDim Is AngularGeneralDimension Then
	    Next
		Call oDrawingDimensions.Arrange(oDimsToBeArranged)
	'Next
End Sub
marcin_otręba
sorry, i had impression after looking at code you provided that one loop will be enough for you.
this is loop from addin so inventor was declared as g_inventorapplication. in illogic jut use
ThisApplication
instead.
drafting4KGWTN
This one worked in terms of excluding dimensions, but not exactly what I'm looking for sorry. Would there be a way to write the code to sort the stacking of dimensions via layers?
