VBA Check design doctor for errors in drawing
pball
Mentor Mentor
pball
Is there a way to check in VBA if the design doctor has found errors in a drawing? I have a mass print script and it'd be handy to be able to skip printing any drawings that have errors like unatached dimensions and such.
Check out my style edits for the Autodesk forums
pball's Autodesk Forum Style
philippe.leefsma
Hi There,
Take a look at the "ErrorManager Interface" in the help files, you can find samples there.
Public Sub ErrorManager()
    Dim errorMng As ErrorManager
    Set errorMng = ThisApplication.ErrorManager
    Dim errors As String
    errors = errorMng.AllMessages
End Sub
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
pball
Thanks for the help. This should help me do exactly what I want to do.
ChristiPedersen
I tried this and all I get is <ErrorsAndWarnings/> even though I can see errors in the sketch doctor.  An suggestions?  Is there maybe a document error manager?
pball
The method above apparently can only pick up errors that happen while your code is running. If you just want to see if a document has an error or not there is a solution in a more recent thread of mine.
https://forums.autodesk.com/t5/inventor-customization/bug-with-checking-errormanager-with-vba/m-p/49...
ChristiPedersen
I read the thread.  Thank you so much.  I will test it.
