VBA aligned views
VBA aligned views
VBA aligned views
Is there any way to find which other view a particular view is aligned to through the API?  I've found things to check whether it is aligned, and to set alignment, but nothing to check which view it's aligned to.
For example:  I have three views, say A, B, and C.  I know that A is aligned to one or the other of B and C, how can I get the API to tell me which?
philippe.leefsma
Hi
What is it that you call "aligned view" exactly? Do you mean projected view?
In case of a projected view you can access the parent using "DrawingView.ParentView" property...
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
