Message 1 of 11
VBA Replace title block definitions in drawing from template file
I have some code to replace the current title block with a title block from a template file. I just don't like how it adds a new title block definition named "copy of titleblock". I'd like to delete or replace the current title block definition so only the newly added one is listed.
Sub test() Dim odrawdoc As DrawingDocument Set odrawdoc = ThisApplication.ActiveDocument If (odrawdoc.DocumentType <> kDrawingDocumentObject) Then Exit Sub Dim oTemplate As DrawingDocument Dim oSourceTitleBlockDef As TitleBlockDefinition Dim oNewTitleBlockDef As TitleBlockDefinition Dim oSheet As Sheet Set oTemplate = ThisApplication.Documents.Open(ThisApplication.FileOptions.TemplatesPath & "template.idw", False) Set oSourceTitleBlockDef = oTemplate.ActiveSheet.TitleBlock.Definition Set oNewTitleBlockDef = oSourceTitleBlockDef.CopyTo(odrawdoc) ' Iterate through the sheets. For Each oSheet In odrawdoc.Sheets oSheet.Activate oSheet.TitleBlock.Delete Call oSheet.AddTitleBlock(oNewTitleBlockDef) Next oTemplate.Close End Sub
I'm just being picky at this point, but I don't want a buildup of title block definitions. We reuse drawings all the time which is why a simple method of updating a title block would be nice. I can just imagine in some years time after a title block update or two there are 20 "copy of copy of copy of .................. titleblock" listed in a drawing file.
