VBA - AddButtonPopup - Need Help, can not assign macro to buttons
Hi to Community;
Please help me to assign a macro for a button definition; and I need to add it to a pop up.
(I need to add a handler for button definition in VBA)
Thanks in advance.
This code works but (the) buttons do not.. 🙂
Sub SetRibbon_UsingClass()
    Dim aClass As clsCustomButton
    Set aClass = New clsCustomButton
    aClass.SetButtonPopup
End Sub
Option Explicit
'Class Module: clsCustomButton
Private WithEvents oButtonDefinition1      As ButtonDefinition
Private WithEvents oButtonDefinition2      As ButtonDefinition
Private Sub oButtonDefinition1_OnExecute(ByVal Context As NameValueMap)
    MsgBox ("oButDefinition1 : command is running")
End Sub
Private Sub oButtonDefinition2_OnExecute(ByVal Context As NameValueMap)
    MsgBox ("oButDefinition2 : command is running")
End Sub
Sub SetButtonPopup()
    Dim oRibbon         As Inventor.ribbon
    Dim oTab            As RibbonTab
    Dim oPanel          As RibbonPanel
    Dim oButDefs        As ObjectCollection
    If ThisApplication.ActiveDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
        Dim ClientId As String
        ClientId = "SampleClientId"
        Set oRibbon = ThisApplication.UserInterfaceManager.Ribbons.item("Assembly")
        Set oTab = oRibbon.RibbonTabs.item("id_TabTools")
        oTab.Active = True
        Set oPanel = oTab.RibbonPanels.Add("Assembly Tool B", "ToolsTabAssemblyPanel-B", ClientId)
        'ADD BUTTON POPUP
        Set oButtonDefinition1 = ThisApplication.CommandManager.ControlDefinitions.AddButtonDefinition( _
            "Button 1", "oButDefinition1", _
            kEditMaskCmdType, ClientId, _
            "Description 1", "ToolTipText 1", , , _
            kDisplayTextInLearningMode)
        Set oButtonDefinition2 = ThisApplication.CommandManager.ControlDefinitions.AddButtonDefinition( _
            "Button 2", "oButDefinition2", _
            "Description 2", "ToolTipText 2", , , _
        Set oButDefs = ThisApplication.TransientObjects.CreateObjectCollection
        oButDefs.Add oButtonDefinition1
        oButDefs.Add oButtonDefinition2
        Call oPanel.CommandControls.AddButtonPopup(oButDefs)
End Sub
I used Visual Studio 2017 (I learned that VS 2019 is not supported by Inventor) and solve the problem.
I found a code from web ; "MenuDemo" and another code for calling existing VBA macros; and manipulate them for my purpose. Thanks.
        Private Sub Button4_Clicked(ByVal context As NameValueMap)
            RunMacro_VBA_RunSheetMetals()
        End Sub
        Public Sub RunMacro_VBA_RunSheetMetals()
            Dim oP As Inventor.InventorVBAProject
            For Each oP In m_inventorApplication.VBAProjects
                If oP.Name = "ApplicationProject" Then
                    Dim oC As Inventor.InventorVBAComponent
                    For Each oC In oP.InventorVBAComponents
                        If oC.Name = "Module_0" Then
                            Dim oM As Inventor.InventorVBAMember
                            For Each oM In oC.InventorVBAMembers
                                If oM.Name = "RunSheetMetals" Then
                                    oM.Execute()
                            Next oM
                    Next oC
            Next
        End Sub
