Iterate script for all assemblies using vba
k14348
k14348
Hi all,
       I have 10 No. of iam files in a folder. I want to iterate bom structure enabled in all assemblies. I have written some code which need to be corrected. Can anybody help?
Karth
Sub IterateBomEnable()
    Dim oPath As String
    oPath = "C:\Users\KTest\"
    Dim oFileName As String
    oFileName = Dir(oPath & "*.iam")
    Do While oFileName <> ""
        Debug.Print "Processing " & oPath & oFileName
        oFileName = Dir
    Loop
For Each oFileName In ???
    Dim oAsmDoc As AssemblyDocument
    Set oAsmDoc = ThisApplication.Documents.Open("oFileName")
    Dim oBom As BOM
    Set oBom = oAsmDoc.ComponentDefinition.BOM
    oBom.StructuredViewEnabled = True
    oBom.PartsOnlyViewEnabled = True
Next
End Sub
fullevent
Hello @k14348
maybe should do what you want.
Private Sub IterateBomEnable()
    Dim objFileSystem As Object
    Dim objVerzeichnis As Object
    Dim objDateienliste As Object
    Dim objDatei As Object
    Set objFileSystem = CreateObject("scripting.FileSystemObject")
    Set objVerzeichnis = objFileSystem.GetFolder("C:\Users\KTest\")
    Set objDateienliste = objVerzeichnis.Files
    For Each objDatei In objDateienliste
		If Not objDatei Is Nothing and instr(objdatei.Name,".iam") > 1 Then
			Set oAsmDoc = ThisApplication.Documents.Open(objdatei.path)
			Dim oBom As BOM
		end if
    Next objDatei
End Sub
regards,
Aleks
Aleksandar Krstic
Produkt- und Projektmanager
k14348
Is there any option to check iam files in subfolders also?
Karth
fullevent
Hello @k14348,
sure.. try this:
Private Sub IAMs_all_Folders()
    Dim Start_Path As String
    Start_Path = "C:\Users\KTest\"    ' Start Folder
    IAMs_aus_Ordner_laden Start_Path
End Sub
Private Sub IAMs_aus_Ordner_laden(sPath As String)
    Dim SubFolders As Object
    Dim SubFolder As Object
    Set objVerzeichnis = objFileSystem.GetFolder(sPath)
    Set SubFolders = objVerzeichnis.SubFolders
        If Not objDatei Is Nothing And InStr(objDatei.Name, ".iam") > 1 Then
            Set oAsmDoc = ThisApplication.Documents.Open(objDatei.FullFileName)
            Dim oBom As BOM
    Next objDatei
    For Each SubFolder In SubFolders
        IAMs_aus_Ordner_laden (SubFolder.path)
    Next SubFolder
End Sub
I hope this helps you.
Greetings
Aleksandar Krstic
