VBA - Add a custom macro on a custom panel
TONELLAL
TONELLAL
I'm trying to add a macro on a custom panel.
I create the tab, the panel, the macro button... but I can't make the button launch the macro !
Here's the code, what's wrong ?
Public Sub test()
    MsgBox ("Hello")
End Sub
Private Sub create_macro_button()
Dim oAssemblyRibbon As Ribbon
Dim oCustomTab As RibbonTab
Dim oCustomPanel As RibbonPanel
Set oAssemblyRibbon = ThisApplication.UserInterfaceManager.Ribbons.item("Assembly")
'Create tab "Custom"
On Error Resume Next
Call oAssemblyRibbon.RibbonTabs("TabCustomIntName").Delete
On Error GoTo 0
Call oAssemblyRibbon.RibbonTabs.Add("Custom", "TabCustomIntName", "CustomId")
Set oCustomTab = oAssemblyRibbon.RibbonTabs("TabCustomIntName")
'Create panel "Custom"
Call oCustomTab.RibbonPanels.item("PanelCustomIntName").Delete
On Error GoTo 0
Call oCustomTab.RibbonPanels.Add("Custom", "PanelCustomIntName", "CustomId")
Set oCustomPanel = oCustomTab.RibbonPanels.item("PanelCustomIntName")
'Macro definition
macroInternalName = "Macro"
Call ThisApplication.CommandManager.ControlDefinitions.item(macroInternalName).Delete
On Error GoTo 0
Dim oMacroDef As MacroControlDefinition
Set oMacroDef = ThisApplication.CommandManager.ControlDefinitions.AddMacroControlDefinition("Module1.test")
Call oCustomPanel.CommandControls.AddMacro(oMacroDef, False)
End Sub
DRoam
The internal name for a macro Control Definition takes on this format:
"macro:<ModuleName>.<SubName>"
So for your macro it would be this:
macroInternalName = "macro:Module1.test"
Everything else in your code looks good. I ran it with that change and it's working fine for me. Try making that change and see if it fixes it.
TONELLAL
Thanks for your answer, but on my computer... nothing happen 😞
I copy my code in a new module called "Module1", declare MacroInternalName = "Macro:Module1.test"
The button is created, but nothing happen when I click it...
I'm on Inventor 2018.
DRoam
Strange, I just don't see anything wrong. Can you send me a screenshot of your VBA editor with both subs ("test" and "create_macro_button") visible?
