error handling. If level of detail does not exist
william
william
Hello
I want to be able to say, change the level of detail to "Export"
If the level of detail "Export" does not exist, then show this message box, else continue.
'Set the level Of detail To Export
LOD_NAME = "Export"
'On Error Resume Next
ThisApplication.ActiveDocument.ComponentDefinition.RepresentationsManager.LevelofDetailRepresentations(LOD_NAME).Activate
If ThisApplication.ActiveDocument.ComponentDefinition.RepresentationsManager.LevelofDetailRepresentations(LOD_NAME) = False
	MessageBox.Show("Level of Detail does not exist", "Error Handling")
'Set the level Of detail back To Default
'ThisApplication.ActiveDocument.ComponentDefinition.RepresentationsManager.LevelofDetailRepresentations("Master").Activate
I have come up with the above but it is not working at the moment.
I am using another piece of code as precedent, which i have pasted below.
	'Dim strFileName = ThisDoc.FileName(False)
	'Save the current document
	'ThisDoc.Save
	'Take the current document's name and create the corresponding idw filename, assuming the same
	strIDWFilename = ThisDoc.ChangeExtension(".idw")
	MessageBox.Show(strIDWFilename, "Title")
	'Close the current document
	'ThisApplication.CommandManager.ControlDefinitions.Item("AppFileCloseCmd").Execute
	'open the indexed file, false opens the file without generating the graphics
	ThisApplication.Documents.Open(strIDWFilename, True)
	If System.IO.File.Exists(strIDWFilename) = False
		MessageBox.Show("Error executing rule. Please ensure that the drawing exists, and has been downloaded from Vault. The drawing must have the same name as this file.", "Error Handling")
Appreciate any help
Regards
Curtis_Waguespack
Hi @william ,
This ilogic example should work.
I hope this helps.
Curtis
LOD_NAME = "Export"
Dim oRepMan As RepresentationsManager
oRepMan = ThisApplication.ActiveDocument.ComponentDefinition.RepresentationsManager
Try
	oRepMan.LevelOfDetailRepresentations(LOD_NAME).Activate
Catch
	MessageBox.Show("The Level of Detail named '" & _
	LOD_NAME & "' does not exist", "Error Handling")
	oRepMan.LevelOfDetailRepresentations("Master").Activate
End Try
william
Thankyou. That works great
