VBA 2021 vs 2022
VBA 2021 vs 2022
admaiora
Mentor Mentor
VBA 2021 vs 2022
admaiora
is there any change between 2021 and 2022 with the use/code of VBA?
I have some code that works great with ... 207 2018  2019 2020 2021...then stop working with 2022.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
bradeneuropeArthur
Can you upload the code, either explain what not works anymore specific?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
admaiora
Hi @bradeneuropeArthur ,
here a video, and attached a sample.
Same files,  works with 2021..doesn't work with 2022
Thanks!
Admaiora
admaiora
Admaiora
NachoShaw
if yo look at your constraint values in 2022, you can see that all of the ones with VBA: are not able to parse and are red. Maybe you need to switch to iLogic in 2022
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
admaiora
Hi thanks.
The question is why this happen. Which is the difference between 2020/2021 and 2022.
If we have used vba is due that that is not possibl with iLogic.
Admaiora
