VB Not My Thing
VB Not My Thing
btillman
VB Not My Thing
btillman
I first started with .NET using VB but quickly moved to C#. I've noticed that the Inventor forum seems to work with VB or VBA. So what was all the hubbub about a few years ago with Autodesk abandoning VBA. At least on the AutoCAD side that's what I was told and it's the main reason I moved th c#.
Owner2229
You can still use VBA in Inventor for makros and VB.Net is still the main language for AddIns. There's a lot of samples for C#, but it's way less than for VB.Net.
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
