I want to lock all my view Representations via vba
k14348
k14348
  i Have one main assembly which has 10 view representations. Now i want to lock all the view representations via vba program. Can anybody help.
I tried something. But its not working im attaching my code for corrections.
Public Sub LockViewRep()
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oRepMgr As RepresentationsManager
Set oRepMgr = oDoc.ComponentDefinition.RepresentationsManager
Dim oViewReps As DesignViewRepresentations
Set oViewReps = oRepMgr.DesignViewRepresentations
Dim oViewRep As DesignViewRepresentation
Set oViewRep = oViewReps.Item(3)
Dim oLock As Boolean
Set oLock = oViewRep.Locked
End Sub
Thanq,
karthikeyan M
+91-9894814348
Owner2229
Try this:
For Each oViewRep In oViewReps
    Call oViewRep.Locked = True
Next
End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
k14348
Not working. Error file attached.
Owner2229
Alright, this should do it:
    On Error Resume Next
Next
End Sub
Mike
