Vb.Net "AddIn" dll - AssetLibrary & Material Asset Problem
isocam
isocam
Can anybody help?
I have the following code that is part of a Vb.Net "AddIn" dll.
The code is taken from the sub: Private Sub ApplicationEvents_OnSaveDocument(.................)
If BeforeOrAfter = EventTimingEnum.kBefore Then
Dim oDoc As Inventor.Document = TryCast(DocumentObject, Inventor.Document)
If oDoc IsNot Nothing And oDoc.DocumentType.Equals(DocumentTypeEnum.kPartDocumentObject) Then
PartMaterial = "Brass, Soft Yellow"
Dim partDoc As PartDocument = oDoc
Dim AssetLib As AssetLibrary = InventorApplication.AssetLibraries.Item(MaterialLibrary)
Dim oMaterial As MaterialAsset
oMaterial = AssetLib.MaterialAssets.Item(PartMaterial)
MsgBox("MATERIAL CURRENTLY SET TO: " + partDoc.ComponentDefinition.Material.Name)
partDoc.ActiveMaterial = oMaterial
MsgBox("MATERIAL UPDATED TO: " + partDoc.ComponentDefinition.Material.Name)
I have a problem with the lines highlighted in blue.
Does anybody know what is wrong?
Many thanks in advance
Darren
bradeneuropeArthur
Change to this and it will work:
Dim AssetLib As AssetLibrary = InventorApplication.AssetLibraries.Item(ThisApplication.ActiveMaterialLibrary.DisplayName)
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Curtis_Waguespack
@isocam, I think  what bradeneuropeArthur said is close, you might just need to change the application reference as shown:
InventorApplication.AssetLibraries.Item(InventorApplication.ActiveMaterialLibrary.DisplayName)
Hope that helps,
Curtis
        Private Sub Events_OnSaveDocument(DocumentObject As _Document,
                      BeforeOrAfter As EventTimingEnum, Context As NameValueMap, ByRef HandlingCode As HandlingCodeEnum)
            If Not DocumentObject Is InventorApplication.ActiveDocument Then Exit Sub 'only trigger on the active file
            If DocumentObject.DocumentType = DocumentTypeEnum.kPartDocumentObject Then
                    Call SetMaterial(DocumentObject)
        End Sub
        Sub SetMaterial(DocumentObject As _Document)
            Dim AssetLib As AssetLibrary = InventorApplication.AssetLibraries.Item(InventorApplication.ActiveMaterialLibrary.DisplayName)
            Dim PartMaterial = "Brass, Soft Yellow"
            MsgBox("MATERIAL CURRENTLY SET TO: " + DocumentObject.ComponentDefinition.Material.Name)
            DocumentObject.ActiveMaterial = oMaterial
            MsgBox("MATERIAL UPDATED TO: " + DocumentObject.ComponentDefinition.Material.Name)
        End Sub
