vb.net - Open file with Inventor View
Jef_E
Message 1 of 15
Jef_E
I'm looking for a way to open a file for viewing with Inventor view. I would like to do this by code, but I can't find any documentation about this subject.
Any ideas, links, tips?
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Replies (14)
Message 2 of 15
frederic.vandenplas
Here you can find the information you need, pretty simple to accomplish
http://modthemachine.typepad.com/my_weblog/2013/03/
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
Message 3 of 15
sundaram1087
HI
        I am in need of display the 3D models in windows form through using inventor View.
       i followed the instructions in your shared link("http://modthemachine.typepad.com/my_weblog/2013/03/"), i tried to show to 3d models in the form i got below problems
        1. Not able to load the "InventorViewCtrl.ocx" file in the windows form Tool Box List even though i registered the OCx file using regsvr32. While adding the control to the tool box it shows the error "self-registration failed"
        Currently am using windows 7 machine with 64 bit configuration.
         Could you please provide the solution for the above problem
Regard
K.Shunmugasundarm
Message 4 of 15
bradeneuropeArthur
Why don't you use 3d pdf!?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 5 of 15
Jef_E
Because the company that employs me uses Inventor 2014 still and this is not available.
Inventor 2014 SP2
Message 6 of 15
sundaram1087
Hi
        i would like to show the models in windows form so that i go for the option inventor View
        Is there any other options for that?
Regards
K.Shunmugasundaram
Message 7 of 15
bradeneuropeArthur
Only a preview? Or other options too?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 8 of 15
sundaram1087
HI
 Preview with different view options(Iso,Front,Side,left,Right)
Regards
K.Shunmugasundaram
Message 9 of 15
bradeneuropeArthur
https://forums.autodesk.com/t5/inventor-customization/createimage-giving-error-while-saveasbitmap-wo...
This will help then...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 10 of 15
sundaram1087
Hi
         Thanks for your options.
         But i would like to have a 3D View in the windows form and also have to rotate  & zoom in etc
Regrads
K.Shunmugasundaram
Message 11 of 15
bradeneuropeArthur
Sorry mis understood the question:
"Preview with different view options(Iso,Front,Side,left,Right)"
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 12 of 15
sundaram1087
HI
       No problem for that
       Is there any option for that?
Regards
K.Shunmugasundaram
Message 13 of 15
bradeneuropeArthur
Yes.
I wrote this anywhere in the past.
I need to take a look as soon as I can...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 15
sundaram1087
Hi
Thanks you
Regards
K.Shunmugasundaram
Message 15 of 15
bradeneuropeArthur
Cannot find the code anymore, but I have found where I have learned it form:
http://adndevblog.typepad.com/manufacturing/2014/10/using-inventor-view-from-64-and-32-bit-process.h...
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
