vb.net list of content center standards
snappyjazz
Message 1 of 12
snappyjazz
Is there a way to access this list of standards through the api? It would be nice to use these standards to help create families for our custom library.
Replies (11)
Message 2 of 12
bradeneuropeArthur
Yes that is possible!
I need to take a look tomorrow for the code!
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 12
snappyjazz
bump
Message 4 of 12
bradeneuropeArthur
Almost forgotten:
Public Sub main()
Dim invapp As Inventor.Application = ThisApplication
        Dim oContentCenter As ContentCenter
        oContentCenter = invapp.ContentCenter
        Dim a As ContentTreeViewNode = oContentCenter.TreeViewTopNode
        LoopGetFromTreeView(a)
    End Sub
    Private Sub LoopGetFromTreeView(oContentTreeViewNode As ContentTreeViewNode)
        Dim oContentTreeViewNodeLoop As ContentTreeViewNode
        'Dim strPath As String = b.DisplayName
        Dim strPath As String = oContentTreeViewNode.FullTreeViewPath
        Dim strFam As String = oContentTreeViewNode.DisplayName
        Dim strExport As String = oContentTreeViewNode.DisplayName
        Dim oContentFamily As ContentFamily
        For Each oContentFamily In oContentTreeViewNode.Families
            If oContentFamily.IsModifiable = True Then
                'MsgBox(f.DisplayName)
                strPath = strPath
                strFam = strPath + ":" + oContentFamily.DisplayName
                'strExport = strPath + ":" + oContentFamily.DisplayName + " Standard: " + oContentFamily.Standard '+ " Template: " + oContentFamily.TemplateFileName + " Type: " + oContentFamily.ContentIdentifier
				strExport = oContentFamily.Standard
                'MsgBox(strFam)
'MsgBox(strExport)
                WriteText(strExport)
        Next
        For Each oContentTreeViewNodeLoop In oContentTreeViewNode.ChildNodes
            LoopGetFromTreeView(oContentTreeViewNodeLoop)
        Next
    End Sub
Public Sub WriteText(StrTextToWrite As String)
        Try
            Dim FileNameTekstfile As String = Nothing
            Try
                FileNameTekstfile = "StandardInCC"
            Catch ex As Exception
            End Try
            Try
                MkDir("C:\StandardsCC\")
            End Try
            Dim FILE_NAME As String = "C:\StandardsCC\ " & FileNameTekstfile & ".txt"
            Dim objWriter As New System.IO.StreamWriter(FILE_NAME, True)
            Try
                objWriter.WriteLine(StrTextToWrite)
            End Try
            objWriter.Close()
        End Try
    End Sub
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 12
snappyjazz
@bradeneuropeArthur
Thank you for your help. It would be perfect if I could access the list directly. Is that possible?
Message 6 of 12
bradeneuropeArthur
  • Don't know what you mean with acces directly?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 12
What I mean by access directly, is that there is a list I can access. The alternative (indirect) way, is the compile a list by sifting through the families.
Message 8 of 12
bradeneuropeArthur
Think not, because the standard is part of the family in the api?
Why is this not sufficient?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 12
snappyjazz
My question from the beginning is asking if the list exists. If it does exist, I suspect that its a property of the content center object. For example:
Dim StanList as List(of String) = InvApp.ContentCenter.StandardsList
If the list doesn't exist, then going through the families one by one and adding the standard to a list is the next best option. Your code helps with that and I appreciate your help, but it doesn't answer my question.
Message 10 of 12
bradeneuropeArthur
Still I don't understand exactly what you need.
Could you please explain it a bit more in detail.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 12
snappyjazz
Maybe I'm thinking about this all wrong. Maybe when you click the standards dropdown it quickly scans all of the families and generates the list at that point. Is this the way you understand it?
Message 12 of 12
bradeneuropeArthur
I think that your assumption is correct!
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
