Vb.Net - Get project file path
premysl.misun
premysl.misun
how I can get in Vb.net directory path of active project file (.ipj) in Inventor 2019?
I want to create some folders in directory of active project file and I do not know how.
Thank you for you answers.
P.
R.Mabery
I believe this is what you are looking for:
InvApp.DesignProjectManager.ActiveDesignProject.WorkspacePath
Randy Mabery
Applications Expert
IMAGINiT Technologies
bradeneuropeArthur
this is what you need:
Public Sub main()
Dim a As Application
Set a = ThisApplication
Dim b As FileOptions
Set b = a.FileOptions
MsgBox b.ProjectsPath
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
NachoShaw
Hey
I made this as a button to open my project folder to save me browsing for it. Hope it helps
Sub ProjectFolder()
    Dim oFileLocations As FileLocations
    Set oFileLocations = ThisApplication.FileLocations
            Dim FolderPath As String
            FolderPath = oFileLocations.Workspace
            Shell "explorer.exe" & " " & FolderPath & "", vbNormalFocus
        End Sub
Nacho
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
JBerns
@NachoShaw ,
Thanks for the useful code. I offer the following suggestion:
FolderPath = oFileLocations.Workspace & "\"
This ends the path with a backslash.
Otherwise, Explorer tries to open the folder as a file. That is what I experienced with Window 10. Perhaps this is not needed in earlier Windows versions.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
p.sangeetaKZZMH
Hi Randy sir,
When i use the same line of code in Electrical, I am getting below error
: 'Public member 'DesignProjectManager' on type 'IAcadApplication' not found.'
