VB.net Find Face by face name.
aaron_lucy
aaron_lucy
I just got Inventor 2019 and i am trying to automate the process of selecting faces and exporting them to a .dxf file.  Does anyone have an example in .net of selecting faces by the faces "Assigned Name"?
MechMachineMan
I've looked through the online programming help and can't see anything about grabbing the face names...
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
BrianEkins
What do you mean by "Assigned Name"?  Faces don't have a name.  However, API attributes are commonly used as a way to associate information with a face and that information can be used later to find that face again.  Essentially, using attributes as a way to name a face.
Brian Ekins
MechMachineMan
@BrianEkins
Looks like a new addition to the UI for 2019...
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2019...
Justin K
BrianEkins
@MechMachineMan, thanks for pointing this out.  I know they had been talking about providing this capability as part of iLogic but I didn't know it had gone into the product.
Regarding the original question, I took a look at this and the iLogic naming is using API attributes to implement it.  Remember that iLogic is an add-in and is using the same API functionality that everyone else is to provide its functionality.  Here's some code that will return a Face or Edge object that has the specified name.
Public Sub GetNameTest()
    Dim doc As PartDocument = ThisApplication.ActiveDocument
    Dim faceOrEdge As Object = GetNamedEntity(doc, "Brian")
End Sub
Public Function GetNamedEntity(doc As Inventor.Document, name As String) As Object
    Dim attribMgr As AttributeManager = doc.AttributeManager
    Dim objsFound As ObjectCollection
    objsFound = attribMgr.FindObjects("iLogicEntityNameSet", "iLogicEntityName", name)
    If objsFound.Count > 0 Then
        Return(objsFound.Item(1))
    Else
        Return(Nothing)
End Function
The AttributeManager utility provides a good view of what's going on.
Brian Ekins
aaron_lucy
Thanks @BrianEkins.  That was exactly what i needed!
