VB.Net - Drawing Sheet Size
premysl.misun
Message 1 of 8
premysl.misun
Hi Everyone,
I have program in VB.Net to change drawing sheet format. It works but only for A4 format is OK - this format I need portrait. For A3, A2, A1 and A0 I need landscape of this format. How can I change it?
Here is code (I probably need to change kA3DrawingSheetSize to antoher name, but I do not know how):
    Private Sub FormatA3_Click(sender As System.Object, e As System.EventArgs) Handles FormatA3.Click
        Dim oDoc As Inventor.DrawingDocument = _invApp.ActiveDocument
        Dim oSheet As Sheet
        oSheet = oDoc.ActiveSheet
        'get current size
        Dim Size As DrawingSheetSizeEnum
        Size = oSheet.Size
        'set new size
        oSheet.Size = DrawingSheetSizeEnum.kA3DrawingSheetSize
        'update sheet to see results
        oSheet.Update()
    End Sub
I tried kA4DrawingSheetSize, kA3DrawingSheetSize, kA2DrawingSheetSize, kA1DrawingSheetSize and kA0DrawingSheetSize but all are portraits.
Thank you very much for your answer.
Premysl
Replies (7)
Message 2 of 8
Jef_E
It seems to me that the changing of size works? Only the orientation is failing you?
Change the orientation by:
Sheet.Orientation Property
Parent Object: Sheet
Description
Gets or sets the orientation of the sheet as it is viewed or printed.
Syntax
Sheet.Orientation() As PageOrientationTypeEnum
Version
Introduced in Inventor version 4
PageOrientationTypeEnum Enumerator
Description
Page Orientation style.
Methods
Name Value Description
kDefaultPageOrientation 10241 Specifies the default setting. The more strongly typed value is returned in a query.
kLandscapePageOrientation 10242 Page is oriented as a Landscape.
kPortraitPageOrientation 10243 Page is oriented as a Portrait.
Version
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Message 3 of 8
you must also use -> oSheet.Orientation = Inventor.PageOrientationTypeEnum.kLandscapePageOrientation
kind regards,
Geert
Message 4 of 8
t_hascj
Hi Premysl,
You can change orientation by property Orientation.
'default orientation
oSheet.Orientation = PageOrientationTypeEnum.kDefaultPageOrientation
'page is oriented as a Landscape
oSheet.Orientation = PageOrientationTypeEnum.kLandscapePageOrientation
'page is oriented as a Portrait
oSheet.Orientation = PageOrientationTypeEnum.kPortraitPageOrientation
S pozdravom,
Jaroslav
Message 5 of 8
premysl.misun
Thank you, works good 🙂
Message 6 of 8
Jef_E
Just for curiosity, was my answer insufficient to solve the problem?
Inventor 2014 SP2
Message 7 of 8
premysl.misun
I am not a software enginner and for me was much easier to copy other commands and put it to my program. And it was mcuh quicker than try it by another way.
Message 8 of 8
Jef_E
But my answer is 100% the same 😄 just not oSheet.orientation but sheet.orientation
I always post a reference from the API as answer as for me it's the most clear and you can learn the most from it, maybe I should stop doing this?
Inventor 2014 SP2
