Model is not Update After entering wrong value
Pratik.Ksoni
Message 1 of 8
Pratik.Ksoni
in my 3D model i have put some limitation in Enter Value, if i add any exceed value then it show message but problem is when i enter incorrect value then it takes incorrect value and when i run the rule then only it update with correct one.
i am looking for when i enter any incorrect value then it shows message and do not take incorrect value.
Please guide me.
Pratik
Replies (7)
Message 2 of 8
b_sharanraj
Hi @Pratik.Ksoni
Try the below Sample Code once 🙂
If Param_X > 100 Then
MessageBox.Show("Message", "Title")
'50 is assumed as Default Value if User Enters more than 100
Param_X = 50 End If
Regards
B.Sharan Raj
Message 3 of 8
Pratik.Ksoni
Thanks for reply,
it works but i am in the requirement of when we enter any incorrect value then model should not be take this value,
say for example if 50 is default value and if i enter 100 then it will take 100 value and update and when i run the rule then it update with rule.
i hope that can clear.
Message 4 of 8
b_sharanraj
In that Case add a Additional Temporary Parameter (Temp_Param_X) and a New Rule with a Event Trigger of After Open Document
'With Event Trigger of After Opening Document Option
Temp_Param_X
= Param_X
and the below code you know where to add 🙂
'Value which ever earlier in the specific part will be back so nothing change will happen in model
Param_X = Temp_Param_X End If
Regards
B.Sharan Raj
Message 5 of 8
b_sharanraj
Temp_Param_X
= Param_X
Regards
B.Sharan Raj
Message 6 of 8
Pratik.Ksoni
Please see attached example.
in this if you enter incorrect value i.e. smaller than 9 then it will show message and model also update with incorrect value but it will not take correct value.
when you run the rule then only it will be update.
Message 7 of 8
It sounds like you need a while loop. Try this:
While    SINKLOCATION_LH<9
    SINKLOCATION_LH = InputBox("SINKLOCATION_LH has incorrect value. Please enter value equal to or greater than 9", "SINKLOCATION_LH", "9")
End While
While    SINKLOCATION_FRONT<9
    SINKLOCATION_FRONT = InputBox("SINKLOCATION_FRONT has incorrect value. Please enter value equal to or greater than 9", "SINKLOCATION_FRONT", "9")
End While
Parameter("COUNTERTOP:1", "SINKLOCATION_LH")=SINKLOCATION_LH
Parameter("COUNTERTOP:1", "SINKLOCATION_FRONT")=SINKLOCATION_FRONT
ThisDoc.Document.Rebuild()
RuleParametersOutput()
iLogicVb.RunRule("Rule0")
iLogicVb.UpdateWhenDone = True
trigger = iTrigger0
Message 8 of 8
b_sharanraj
Try this code once 🙂
Temp_SINKLOCATION_LH = Parameter("COUNTERTOP:1", "SINKLOCATION_LH")
Temp_SINKLOCATION_FRONT = Parameter("COUNTERTOP:1", "SINKLOCATION_FRONT")
While SINKLOCATION_LH < 9
    MessageBox.Show("INCORRECT VALUE", "SINKLOCATION_LH")
    SINKLOCATION_LH = Temp_SINKLOCATION_LH
End While
While SINKLOCATION_FRONT < 9
    MessageBox.Show("INCORRECT VALUE", "SINKLOCATION_FRONT")
    SINKLOCATION_FRONT = Temp_SINKLOCATION_FRONT
End While
Parameter("COUNTERTOP:1", "SINKLOCATION_LH") = SINKLOCATION_LH
Parameter("COUNTERTOP:1", "SINKLOCATION_FRONT") = SINKLOCATION_FRONT
InventorVb.DocumentUpdate()
Regards
B.Sharan Raj
