Vb.net create virtual component and set quantity
Message 1 of 8
Hi everyone,
I try to create a button to add a virtual component in an assembly and set the quantity.
I found some information but nothing that really helps me. And I need some help.
Here is what I started :
Private Sub VirtualComponents_OnExecute(Context As NameValueMap) Handles VirtualComponents.OnExecute
Dim oApplication As Inventor.Application = GetObject(, "Inventor.Application") Dim oAssDoc As AssemblyDocument oAssDoc = oApplication.ActiveDocument Dim oAssDef As AssemblyComponentDefinition oAssDef = oAssDoc.ComponentDefinition Dim oMatrix As Matrix oMatrix = oApplication.TransientGeometry.CreateMatrix Dim oNewOcc As ComponentOccurrence oNewOcc = oAssDef.Occurrences.AddVirtual("MyVirtual", oMatrix) Dim oCVirtualCompDef As VirtualComponentDefinition oCVirtualCompDef = oNewOcc.Definition Dim oQuantity As Double = InputBox("Quantity") oCVirtualCompDef.BOMQuantity.SetBaseQuantit(BOMQuantityTypeEnum.kEachBOMQuantity, oQuantity) End Sub
Replies (7)
Message 2 of 8
marcin_otręba
You must find this virtual component in bom, when you get corresponding row use row.TotalQuantity=oQuantity.
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 3 of 8
Yes, but I can not find the line corresponding to my component:
Here is what I have :
oAssDef.BOM.BOMViews.Item(1).BOMRows.Item(1).TotalQuantity = oQuantity
Message 4 of 8
marcin_otręba
most likely it will be last row in your Bom because you just added this component right ?
Give some for each row and  if...then statement first for check if row.componentdefinitions.item is vistualcomponent then some check if name is equal to you component name.
Message 5 of 8
That's what I do not know how to do !
Message 6 of 8
marcin_otręba
This code search using part number, so it must be set first when you add virtcomp: or change to what ever you want
Dim bom As Inventor.BOM = ass.ComponentDefinition.BOM
bom.StructuredViewEnabled = True
Dim bomview As Inventor.BOMView = bomm.BOMViews.Item(2)
For Each row As Inventor.BOMRow In bomview.BOMRows
Dim oCompDef As Inventor.ComponentDefinition
oCompDef = row.ComponentDefinitions.Item(1)
Dim oPartNumProperty As Inventor.Property
If TypeOf oCompDef Is Inventor.VirtualComponentDefinition Then
'Get the file property that contains the "Part Number"
'The file property is obtained from the virtual component definition
oPartNumProperty = oCompDef.PropertySets _
.Item("Design Tracking Properties").Item("Part Number")
If oPartNumProperty.Value = m_selectedItem.ItemNum Then
row.TotalQuantity = i
End If
End If
Next
Message 7 of 8
marcin_otręba
but as i said in your scenario it will be last row because you just added your component. so if you want to change qty right away then use bomview.BOMRows.rows.item(bomview.rows.count)
Message 8 of 8
I succeeded.
Thanks !
