Vb.Net - CheckedListBox - Check If Any Item Has Been Checked
isocam
isocam
Can anybody help?
I am writing a Vb.Net application for use with Autodesk Inventor, but, I cannot get the following code to work.
For Counter = 0 To CheckedListBox1.Items.Count - 1
       If CheckedListBox1.GetItemChecked(Counter) Then
               MsgBox("A CHECKED ITEM HAS BEEN FOUND")
              Exit For
Next
I have a CheckedListBox populated with various items. All I am trying to do is to determine if any item has been checked.
I have searched the Internet for the solution but I have not found anything to resolve the problem.
Many thanks in advance!
Kind Regards
Darren
bradeneuropeArthur
And what do you want after you know the checked items?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
bradeneuropeArthur
 For Each item As Object In CheckedListBox1.CheckedItems
            MsgBox(item)
 Next
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
