VaultOption
VaultOption
JoAntt
VaultOption
JoAntt
I use this to check out files
invApp.CommandManager.ControlDefinitions.Item("VaultCheckoutTop")
How do i define options with this?
Its the closest i can find that may have something to do with it.
invApp.CommandManager.ControlDefinitions.Item("VaultOption")
I need to set the "Include children" and so on.
bradeneuropeArthur
You need to use the Vault API for that kind of things. Only with the Inventor api this will not work.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
g.georgiades
Find this file here
C:\Users\<USERNAME>\AppData\Roaming\Autodesk\Inventor 2023 Vault Addin\ApplicationPreferences.xml
If Inventor is closed - you can simply modify this file and the changed settings will take effect the next time you open Inventor.
If Inventor is open - read the ID and Name from the file and you can use this iLogic snippet to set the values.
Imports Autodesk.DataManagement.Client.Framework.Forms
AddReference "Autodesk.DataManagement.Client.Framework.Forms.dll"
'Library.ApplicationPreferences.Load() 'Load modified settings if file edited outside of Inventor process.
Library.ApplicationPreferences.Set("CheckInDialogOptions", "IncludeChildren", True) 'Directly sets the setting right from the iLogic Rule.
See this post to edit vault prompts. Those are handled differently.
https://forums.autodesk.com/t5/inventor-programming-ilogic/is-there-a-why-to-change-promt-or-not-bei...
JoAntt
Thank you!
Skadborg.NTI
Oops - wrong thread
