Vault connection with iLogic
ThatWorksForMe
ThatWorksForMe
I use Inventor/Vault Pro 2018 at the moment and so following code works fine.
On the new version (2022) this code works also (without errors) but the messagebox is empty.
Header of this file:
'API for Vault connection
AddReference "Autodesk.Connectivity.WebServices.dll"
Imports AWS = Autodesk.Connectivity.WebServices
AddReference "Autodesk.DataManagement.Client.Framework.Vault.dll"
Imports VDF = Autodesk.DataManagement.Client.Framework
AddReference "Connectivity.Application.VaultBase.dll"
Imports VB = Connectivity.Application.VaultBase
File:
	Dim mVltCon As VDF.Vault.Currency.Connections.Connection
	mVltCon = VB.ConnectionManager.Instance.Connection
	If  mVltCon Is Nothing Then
		MessageBox.Show("Not Logged In to Vault")
		Return "error"
	Dim VaultPath As String = oDoc.FullFileName
	'Dim VaultPath As String = ThisDoc.PathAndFileName(True)
	VaultPath = VaultPath.Replace(Environ("USERPROFILE") & "\Workspace\", "$/")
	'flip the slashes
	VaultPath = VaultPath.Replace("\", "/")
	Dim VaultPaths() As String = New String() {VaultPath}
	Dim wsFiels() As AWS.File = mVltCon.WebServiceManager.DocumentService.FindLatestFilesByPaths(VaultPaths)
	MsgBox(wsFiels(0).FileRev.Label.ToString)
	Dim mFileIt As VDF.Vault.Currency.Entities.FileIteration = New VDF.Vault.Currency.Entities.FileIteration(conn,wsFiels(0))
	Dim lifeCycleInfo As VDF.Vault.Currency.Entities.FileLifecycleInfo = mFileIt.LifecycleInfo
	If (GetData = "SetRev") And oDoc.FullFileName.Contains(ThisDoc.FileName(False)) = True Then
		MsgBox(iProperties.Value(oDoc, "Custom", "TEST_Version") & "," & wsFiels(0).FileRev.Label)
The problem is, that the Messagebox
is always empty.
In Inventor 2018 it is filled correctly, but in Inventor 2022 not.
I have already seen a solution by MarkusKoechl, but is there an easy solution for that problem with this code?
Regards
PDM/CAD Administrator
Using Inventor/Vault 2024.3
bradeneuropeArthur
Replace this
with this
VaultPath = VaultPath.Replace(Environ("USERPROFILE") & "\Workspace\", "$")
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
ThatWorksForMe
Thanks @bradeneuropeArthur
My fault was more simple. I apologize for wasting your time. I forgot "2022" in the path for the workspace.
**** hardcoded directories.
