Using Rules to adjust dimensions
Hi all,
I am trying to adjust a set of dimensions when a user parameter is set but can't get my code to run.
My code is as follows;
If S1=2 Then d87=19.1,d86=152,d88=78,d85=92.1,d89=63,d104=60.3
If S1=4 Then d87=23.9,d86=229,d88=135,d85=157.2,d89=76,d104=114.3
Could someone help me fix this.
bradeneuropeArthur
If S1=2 Then
d87=19.1
d86=152
d88=78
d85=92.1
d89=63
d104=60.3
If S1=4 Then
d87=23.9
d86=229
d88=135
d85=157.2
d89=76
d104=114.3
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
