I'm on 2025
I've found previously that orange text means it's missing something when writing other things.
When I run the rule, it runs through all model states (like 600+). I see my forms change to what they should as it moves from one model state to the next. But even when it's finished it still shows I need to click 'Local Update' when I activate any new model states made after editing the Model States spreadsheet
A little context.
Example:
I want a board that can be different lengths, widths, and thicknesses
Thickness Options: 2", 4"
Widths Options: 4", 6", 8", 10", 12"
Length Options: 6', 8', 10', 12', 16'
So I made Model states for all combos that could be 2" Thick
1. 2" x 4" x 6'
2. 2" x 6" x 6'
3. 2" x 8" x 6'
4. 2" x 10" x 6'
5. 2" x 12" x 6'
6. 2" x 4" x 8'
7. 2" x 6" x 8'
8. 2" x 8" x 8'
9. 2" x 10" x 8'
10. 2" x 12" x 8'
11. 2" x 4" x 10'
12. 2" x 6" x 10'
13. 2" x 8" x 10'
14. 2" x 10" x 10'
15. 2" x 12" x 10'
16. 2" x 4" x 12'
17. 2" x 6" x 12'
18. 2" x 8" x 12'
19. 2" x 10" x 12'
20. 2" x 12" x 12'
21. 2" x 4" x 16'
22. 2" x 6" x 16'
23. 2" x 8" x 16'
24. 2" x 10" x 16'
25. 2" x 12" x 16'
I then Edited the Model States via spreadsheet by copying Row 1-25, and changing the thickness to 4in in order to make new model states that are 4" Thick (Model States 26-50)
When I save and exit the spreadsheet, it makes the new model states that I added. Thought this was great, I need to make literally 30'000 model states for my actual part. But the model states made from editing the spreadsheet still show I need to manually click and update them individually, even after running the rule you wrote.
I click on Model State '1.' and the form shows '2" Thick, 4" Wide, 6' Long' and it doesn't need updated. But then I click on the new Model State '26.' and the form shows '4" Thick, 4" Wide, 6' Long' like it should, but the model itself is still actually showing as if it's Model State '1.' until I manually update it.
Is there anything you can suggest I change to make it work?
