Sketchline in respect to assembly
Cadkunde.nl
Cadkunde.nl
Hello Forum,
Working with objects and their proxies have always been a challange for me.
Previously I asked how to find the 'native object' from a sketchline you select from a top assembly
https://forums.autodesk.com/t5/inventor-programming-ilogic/select-a-sketchline-from-top-assembly-the...
Now I'm stuck trying to do the exact opposite
I have an automation that creates railings on platforms
You select the line:
and a railing is created
Now I want to find any intersecting lines from the assembly.
Finding this one:
When I create a platform, I create an object in which I store the 4 sketchlines it's created with.
But these sketchlines are in respect of the place document (an IPT, the green surface)
I need them from the respect of the assembly or I can't compare the geometry of them, since one is the X Y Z from its IPT and the other is from the assembly
Problem in short:
You have a assembly with 1 part
in that part you have 1 sketch with 1 sketchline
ilogic:
Dim odoc as partdocument = thisdoc.document
Dim oline as sketchline = odoc.componentdefinition.sketches(1).Sketchlines(1)
How to get the proxy of oline from the assembly?
Cadkunde.nl
My bad
Dim line As SketchLine = edge.line
Dim lineproxy As SketchLineProxy = Nothing
AdjecantPlatform.Occurrence.CreateGeometryProxy(line, lineproxy)
Works not only for workgeometry but also perfectly for sketchlines
Andrii_Humeniuk
Hi @Cadkunde.nl .
I hope I understood your question correctly. You need to get the proxy geometry of a particular sketch line from a particular part. The following iLogic code, as an example, selects the first sketch and the first line on the sketch in the first part:
Dim oADoc As AssemblyDocument = ThisDoc.Document
If oADoc Is Nothing Then Exit Sub
Dim oADef As AssemblyComponentDefinition = oADoc.ComponentDefinition
Dim oOccs As ComponentOccurrences = oADef.Occurrences
Dim oOcc As ComponentOccurrence = oOccs(1)
Dim oPDef As PartComponentDefinition = oOcc.Definition
Dim oLine As SketchLine = oPDef.Sketches(1).SketchLines(1)
Dim oLineProx As SketchLineProxy = Nothing
Call oOcc.CreateGeometryProxy(oLine, oLineProx)
Call oADoc.SelectSet.Select(oLineProx)
Andrii Humeniuk - CAD Coordinator, Autodesk Certified Instructor
LinkedIn | My free Inventor Addin | My Repositories
Did you find this reply helpful ? If so please use the Accept as Solution/Like.
