using iLogic to read latest revision date
Message 1 of 22
All-
I've been sifting through several iLogic posts on the rev table, and I found one close - about assigning a date ... but what I want to do is read the date.
We have a rule to generate a PDF with the following format:  "drawing number_rev letter_pg to pgs_rev date.pdf
as an example - a rev d file with 3 sheets would look like this.    0070721_D_1-3_031717.pdf
date is formatted mmddyy
I read the drawing number from the filename, the rev from iproperties, sheet count from drawing file, and rev I was using system date.
the issue - we had to go back and make pdfs for files that we quick-changed- and skipped revisions, skipped initial pdf creation.  I know, bad practice ..
anyway - we went back and made PDF - but illogic put today's date on instead which now doesn't match when the revision was actually completed - a week or so ago.
how can I read the revision table to pull the latest revision date ... and grab that date as my pdf file date.
I was going to use last modified file property - but that changes when you save the file - and we run the pdf rule on file close.
thanks -
Replies (21)
Message 2 of 22
Ktomberlin
I think I understand the question, all you have to do is reverse the order instead of iproproperty  = variable, variable = iproproties or in this case revision table value.  Now depending on your revision table you'll need to adjust the line below
RevDate = oRow.Item(3).Text
to a different number if the date you want to grab is in a different field (1), (2), (3). etc.  There is some extra stuff attached but you should get the idea.
Hope this helps.
Dim oDoc as Document = ThisApplication.ActiveDocument
Dim editDoc As Document
Dim oDrawDoc As DrawingDocument = oDoc
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
editDoc = oDrawDoc.ActiveSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument
Dim invDesignInfo As PropertySet
invDesignInfo = editDoc.PropertySets.Item("Design Tracking Properties")
Dim invPartNumberProperty As Inventor.Property
invPartNumberProperty = invDesignInfo.Item("Part Number")
invSummaryInfo = oDoc.PropertySets.Item("Inventor Summary Information")
invRevNumberProperty = invsummaryInfo.Item("Revision Number")
Dim oPropSets As PropertySets
oPropSets = oDoc.PropertySets
Dim oPropSet As PropertySet
oPropSet = oPropSets.Item("Design Tracking Properties")
Dim RevDate As Date
Dim MyDwgRev As String
MyDwgRev = invRevNumberProperty.Value
If MyDwgRev > 0
    Dim oTable As RevisionTable = oSheet.RevisionTables.Item(1)
    'total number of revision rows
    Dim N As Integer = oTable.RevisionTableRows.Count
    'the last row in the table
    Dim oRow As RevisionTableRow = oTable.RevisionTableRows.Item(N)
    Else
    RevDate = oPropSets.Item("Design Tracking Properties").Item("Engr Date Approved").Value
MessageBox.Show(RevDate, "Title")
Message 3 of 22
Owner2229
Little correction, cleaning and shortening here:
You can replace "oModel" with "oDoc" if you want to pull the iProperties from the drawing document instead of the model document.
Dim oDoc As Document = ThisApplication.ActiveDocument
If oDoc.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then Exit Sub
Dim oSheet As Sheet = oDoc.ActiveSheet
If oSheet.DrawingViews.Count = 0 Then Exit Sub Dim oModel As Document = oSheet.DrawingViews(1).ReferencedDocumentDescriptor.ReferencedDocument Dim iDesign As PropertySet = oModel.PropertySets("Design Tracking Properties") Dim iSummary As PropertySet = oModel.PropertySets("Inventor Summary Information") Dim PartNumber As String = iDesign("Part Number").Value Dim RevNumber As String = iSummary("Revision Number").Value
Dim RevDate As Date If RevNumber <> vbNullString Then Dim oTable As RevisionTable = oSheet.RevisionTables.Item(1) Dim oRows As RevisionTableRows = oTable.RevisionTableRows Dim oRow As RevisionTableRow = oRows.Item(oRows.Count) RevDate = oRow.Item("DATE").Text Else RevDate = iDesign.Item("Engr Date Approved").Value End If Dim NewFileName As String = PartNumber & "_" & RevNumber & "_1-" & oDoc.Sheets.Count & "_" & RevDate
MsgBox("Revision Date: " & RevDate & vbLf & "New File Name: " & NewFileName)
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 4 of 22
thanks for the replies - as soon as I get a chance (hopefully today yet) I'll try the solutions and close this out if it works....
I'll be in touch.
Message 5 of 22
        i was using your ilogic code to print Rev and date, but only the problem is i am unable to print the creation date / Mfg. Approved Date. This works only if i had a revision table. Is there any way i can print if i am not using in rev. table. Please respond
Message 6 of 22
MechMachineMan
@Anonymous Yes....
Change the code...
Or fix your template so it isn't populating a revision number that shouldn't be there according to the code..............
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 7 of 22
Hello Actually i a good with revision number, when you see this lines in codes
Dim RevDate As Date
Else
I am able to print date from revision tables, what if I don’t have a revision table it has to print either a creation date or mfg date. After the line else the rev date is not calling to print output on message.
Could you please suggest what to add in that lines to print
Message 8 of 22
MechMachineMan
@Anonymous
Reading the code in the post I'm responding to, it says that if the REVISION NUMBER IPROPERTY is blank, it will use the Engineering date approved.
So... to make it mfg date approved or creation date, simply change the line that says to use the engineering date.
RevDate = iDesign.Item("Mfg Date Approved").Value
or
RevDate = iDesign.Item("Creation Date").Value
Justin K
Message 9 of 22
       I did the same way by changing the code to creation date or mfg approved date, but it was not calling the date even after. i was thinking is there any way i can pull the date from iProperties Property creation date.
Message 10 of 22
MechMachineMan
Looks like you can only get "creation time" and have to extract the date from it.
http://modthemachine.typepad.com/my_weblog/2010/02/accessing-iproperties.html
https://forums.autodesk.com/t5/inventor-customization/get-date-value/td-p/2155783
date = Format(iDesign.Item("Creation Date").Value, "mm-DDD-yy")
Justin K
Message 11 of 22
Still Doesn't work
See What i got let me know if any thing is wrong
SyntaxEditor Code Snippet
Dim iDesign As PropertySet = oDoc.PropertySets("Design Tracking Properties")
Dim iSummary As PropertySet = oDoc.PropertySets("Inventor Summary Information")
Dim RevDate As Date
RevDate = iDesign.Item("Design Tracking Properties").Item("Creation Time").Value
Else
RevDate =  Format(iDesign.Item("Creation Date").Value, "mm-DDD-yy")
Dim NewFileName As String = PartNumber & "_REV-" & RevNumber & "_1-" & oDoc.Sheets.Count & "_" & RevDate &"_" & todayDate
Message 12 of 22
MechMachineMan
Give this a whirl and let me know what msgboxes pop up.
Dim oSheet As Sheet = oDoc.ActiveSheet If oSheet.DrawingViews.Count = 0 Then Exit Sub Dim iDesign As PropertySet = oDoc.PropertySets("Design Tracking Properties") Dim iSummary As PropertySet = oDoc.PropertySets("Inventor Summary Information") Dim PartNumber As String = iDesign("Part Number").Value Dim RevNumber As String = iSummary("Revision Number").Value
Dim RevDate As String
MsgBox("MSG#1a" & vblf & _
"RevDate pulled from Rev Table..... Rev Number iProp being non-blank caused this to happen" & vblf & _
"Result: " & RevDate) Else RevDate = Format(iDesign.Item("Creation Time").Value, "mm-DDD-yy")
MsgBox("MSG#1b" & vblf & "RevDate pulled from Creation Time!" & vblf & "Result: " & RevDate) End If Dim NewFileName As String = PartNumber & "_REV-" & RevNumber & "_1-" & oDoc.Sheets.Count & "_" & RevDate &"_" & todayDate MsgBox("Revision Date: " & RevDate & vbLf & "New File Name: " & NewFileName)
Justin K
Message 13 of 22
Error on Line 21 : Argument not specified for parameter 'format' of 'Public Shared Function Format(enumType As System.Type, value As Object, format As String) As String'.
Highlited is the line 21 (Bold Letters)
    MsgBox("MSG#1a" & vbLf & "RevDate pulled from Rev Table..... Rev Number iProp being non-blank caused this to happen")
Else
    MsgBox("MSG#1b" & vbLf & "RevDate pulled from Creation Time!" & vbLf & "Result: " & RevDate)
Message 14 of 22
MechMachineMan
forgot this is iLogic. lol.
Try this:
Else
    RevDate =  iDesign.Item("Creation Time").Value.ToString("yyyymmdd")
Justin K
Message 15 of 22
I was getting this message
Error in rule: New, in document: 152-001.idw
The parameter is incorrect. (Exception from HRESULT: 0x80070057 (E_INVALIDARG))
Message 16 of 22
MechMachineMan
Well, I just revised it so it uses the rev table if it finds one, or creation time if it doesn't.
You should modify the .ToString("") line to use whatever date format matches your standard.
You should modify the oRevTableDateColumn integer to match your revision table styles.
oRevTableDateColumn = 3
If oSheet.RevisionTables.Count > 0 Dim oTable As RevisionTable = oSheet.RevisionTables.Item(1) Dim oRows As RevisionTableRows = oTable.RevisionTableRows Dim oRow As RevisionTableRow = oRows.Item(oRows.Count) RevDate = oRow.Item(oRevTableDateColumn).Text
End if Dim NewFileName As String = PartNumber & "_REV-" & RevNumber & "_1-" & oDoc.Sheets.Count & "_" & RevDate &"_" & todayDate MsgBox("Revision Date: " & RevDate & vbLf & "New File Name: " & NewFileName)
Justin K
Message 17 of 22
Even though i matched my format styles i get the following error message
Conversion from string "yyyymmdd" to type 'Integer' is not valid.
Message 18 of 22
Owner2229
Hey, try this instead:
RevDate = DateTime.Parse(iDesign.Item("Creation Time").Expression).ToString("yyyy/MM/dd")
Or, to use the original format of the code:
Dim RevDate As Date
MsgBox("CreationDate: " & RevDate.ToString("yyyy/MM/dd"))
Mike
Message 19 of 22
              Seems like this will work, i don't understand it pops up a message End of Statement Expected. Can you help me out
Message 20 of 22
MechMachineMan
@Owner2229 and after 1.5 hrs of searching, I was almost convinced there was no easy way to convert the date. Smiley LOL Thanks for proving me wrong!
@Anonymous the below code should work for you. You should note that all it does is shows a message box with the date format, and doens't actually populate it anywhere.
If oDoc.DocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then MsgBox("Drawings only!"): Exit Sub
If oSheet.DrawingViews.Count = 0 Then MsgBox("No Views on Drawing... Aborting Rule!"): Exit Sub
RevDate =  DateTime.Parse(iDesign.Item("Creation Time").Value).ToString("yyyyMMdd")
Justin K
