Using iLogic to enable or disable hardware in an iAssembly
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I was referred to post to this forum from the Inventor Forum. I have a machine design that I am working on that has 200+ different configurations. I need to generate a model, print and BOM for each machine configuration. This is great, until a change is required that effects the entire product line, such as a logo modification or sheet metal change. To reduce the redundancy, I wanted to use an iAssembly with sub iAssemblies to generate all of the models in 1 file. The table option seemed perfect as I can assign part numbers and the models are generated based on the options in the table.
I however want to limit the items that are in the table to these 4 sub iAssemblies:
Transformer (1-10)
Bridge (1-2)
Output Style (1-4)
UI Style (1-3)
So when I select Transformer 1, Bridge 1, Output 1 and UI1, I want the model to use iLogic to "know" that Bridge 1 uses 2 cables and 14 fasteners and since Bridge 2 uses uses 3 cables and 21 fasteners, we need to exclude 1 cable and 7 fasterners.
If Component.iComponentIsActive("750650110:1") Then Component.InventorComponent("RING TERMINAL .25 12-10GA RING TERMINAL .25 12-10GA-Silver:3").Excluded = True Component.InventorComponent("Plain Washer - Inch 1/4 - Regular - Type B:10").Excluded = True Component.InventorComponent("Hex Nut - Inch 1/4 - 28:8").Excluded = True Component.InventorComponent("Split Lock Washer - Inch 0.25:8").Excluded = True Component.InventorComponent("HHCS - Inch 1/4-28 UNF - 0.75:7").Excluded = True Component.InventorComponent("Plain Washer - Inch 1/4 - Regular - Type B:8").Excluded = True Component.InventorComponent("Hex Nut - Inch 1/4 - 28:6").Excluded = True Component.InventorComponent("Split Lock Washer - Inch 0.25:6").Excluded = True Component.InventorComponent("HHCS - Inch 1/4-28 UNF - 0.75:6").Excluded = True Component.InventorComponent("Plain Washer - Inch 1/4 - Regular - Type B:7").Excluded = True Component.InventorComponent("Hex Nut - Inch 1/4 - 28:5").Excluded = True Component.InventorComponent("Split Lock Washer - Inch 0.25:5").Excluded = True Component.InventorComponent("Plain Washer - Inch 1/4 - Regular - Type B:5").Excluded = True Component.InventorComponent("Hex Nut - Inch 1/4 - 28:3").Excluded = True Component.InventorComponent("Split Lock Washer - Inch 0.25:3").Excluded = True Component.InventorComponent("HHCS - Inch 1/4-28 UNF - 0.75:3").Excluded = True Component.InventorComponent("HHCS - Inch 1/4-28 UNF - 0.75:4").Excluded = True
I have tried this code and it does "hide" the parts that are not supposed to be there, but it does not actually exclude them. When I rebuild the model they reappear. Is the option to exclude parts only linked to a table entry in the iAssembly or can iLogic include or exclude them as well.
