Using iLogic to change parameter
Message 1 of 8
Hello! First off, pardon my bad English.
I am kind of new to iLogic and I am looking to do something in Inventor, but I cant figure out how.
When I import a part from content center, a tube in this case, I get a length parameter called <PL>.
I am using this parameter in the parts lists, so it shows "=Outer diameter x thickness x <PL>"
However I don't want trailing zeros, leading zeros or units string to be shown.
I know I can open the parameters window, right click the parameter, then click custom property format and then uncheck these boxes and its fine.
But I want to know if there is a smarter way to do this, like creating a rule to execute on all the parts?
I have around 500 pipes with the parameter <PL> that needs to be changed.
Can someone out there help me find a smarter way to do this?
All help appreciated.
Replies (7)
Message 2 of 8
Curtis_W
Hi ystrm,
There is an example of this at this link:
http://forums.autodesk.com/t5/Autodesk-Inventor/ilogic-Adding-User-Parameters-with-Custom-Properties...
I hope this helps.
Curtis
Message 3 of 8
Thanks for the reply
Could you explain further what I have to do with this code?
Say my parameter is PL
How should that code look like in a rule?
Message 4 of 8
Curtis_W
Hi ystrm,
It occured to me that the example I linked to didn't show everything you were after, and it used fractions for the precision. Here is another example using your parameter name.
I hope this helps.
Curtis
'get the parameter
oPL = Parameter.Param("PL")
'export the paramter as an iProperty
oPL.ExposedAsProperty = True
'set the parameter as a custom property
oFormat=oPL.CustomPropertyFormat
'set the custom iProperty as a text type
oFormat.PropertyType=Inventor.CustomPropertyTypeEnum.kTextPropertyType
'set the precision
oFormat.Precision=Inventor.CustomPropertyPrecisionEnum.kThreeDecimalPlacesPrecision
'set the unit type
oFormat.Units="mm"
'set to show/not show the unit string (use True to show)
oFormat.ShowUnitsString=False
'set to show/not show the trailing zeros (use True to show)
ShowTrailingZeros = False
'set to show/not show the leading zeros (use True to show)
ShowLeadingZeros = False
'write values to the description property
iProperties.Value("Project", "Description") = "=Outer diameter x thickness x <PL>"
Message 5 of 8
Hi again!
Thank you very much for the detailed information.
It did not solve everything though.
It removes the units string, but not the trailing zero's. I still get "250,000" in the parameter / custom iprop.
Any ideas?
Message 6 of 8
Curtis_W
Hi ystrm,
My applogies, I had a mistake in the previous example.
I had this:
where it should have been this:
oFormat.ShowTrailingZeros = False
Here is the updated code:
'get the parameter
'set the precision
'set the unit type
oFormat.Units="mm"
oFormat.ShowLeadingZeros = False
 I hope this helps.
Curtis
Message 7 of 8
That did it!
Thanks alot Smiley Happy
Message 8 of 8
bionorica2015
