VBA/iLogic Rule to Rename Model Parameter NAMES
bionorica2015
Message 1 of 19
bionorica2015
Hello!
I have this code written by me:
Option Explicit
Public Sub Rename()
Dim i As Integer
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
If oDoc.DocumentType = kPartDocumentObject Then
Dim oPartCompDef As PartComponentDefinition
Set oPartCompDef = oDoc.ComponentDefinition
For i = 1 To oPartCompDef.Parameters.ModelParameters.Count
Dim param As String
param = "d" & i
Dim pName As String
pName = oPartCompDef.Parameters.ModelParameters(i).Name
pName = param
oDoc.Update2 (True)
Next i
Else
Exit Sub
End Sub
I want to automatically rename model parameter names by numeric order: d1, d2, d3, ...
Please help with it - to write it correctly so it worked
Replies (18)
Message 2 of 19
Ralf_Krieg
Hello
You should first write all parameter names to a temporary name. Otherwise, if you try to rename parameter d14 to d8 and another parameter named d8 already exist, it will fail.
Option Explicit ON
Dim i As Integer
Dim oDoc As PartDocument=ThisDoc.Document
	Dim oPartCompDef As PartComponentDefinition = oDoc.ComponentDefinition
		oPartCompDef.Parameters.ModelParameters(i).Name = "tmpd" & i.ToString
	Next i
		oPartCompDef.Parameters.ModelParameters(i).Name = "d" & i.ToString
	Next i
R. Krieg
RKW Solutions
www.rkw-solutions.com
Message 3 of 19
bionorica2015
hank you very much that You answered.
There is a little error:
I need model parameter renamed to d1, d2, d3, ....
But with Your code(I changed some , because it didnt work) I get tmpd1, tmpd2, ...
Here is code now:
Option Explicit
Public Sub Rename()
Dim i As Integer
Next i
Dim param As String
param = "t" & i
Dim pName As String
pName = param
Next i
End Sub
How can I solve this?
Message 4 of 19
A.Acheson
This post link appears in 6 other posts and many have no connection to your requested help. Please refrain from duplicated posting as it will have the opposite effect.
If it is an ilogic related question, please use the inventor ilogic forum as it will likely get a quicker and more target response there.
Regards
Alan
Message 5 of 19
Ralf_Krieg
Hello
Your code does exact the same my code does. It only splits it in 4 more lines of code. I can not reproduce the error. I've added a feedback, so you are informed in case of an error and maybe this helps to find a reason.
Option Explicit ON
Dim i As Integer
Dim stmpString As String="tmp"
	Try
			oPartCompDef.Parameters.ModelParameters(i).Name = stmpString & i.ToString
		Next i
	Catch
		MsgBox("Parameter " & oPartCompDef.Parameters.ModelParameters(i).Name & " could not be renamed to " & stmpString & i & vbCrLf & "Please check results.", MsgBoxStyle.Critical,"Rename Model Parameters")
	end try
	Try
		Next i
	Catch
		MsgBox("Parameter " & oPartCompDef.Parameters.ModelParameters(i).Name & " could not be renamed to " & "d" & i & vbCrLf & "Please check results.", MsgBoxStyle.Critical,"Rename Model Parameters")
	End Try
R. Krieg
RKW Solutions
Message 6 of 19
bionorica2015
tOO many errors occured
Here is screen:
Message 7 of 19
Ralf_Krieg
Hello
You are aware this is iLogic code? Your screenshot shows VBA editor.
R. Krieg
RKW Solutions
Message 8 of 19
bionorica2015
Yes. it is my mistake that I didnt say you. Yes, I am writing vba code for renaming model params.
This code works:
Option Explicit
Sub Rname()
Dim i As Integer
Dim tmp As String
tmp = "tmp"
oPartCompDef.Parameters.ModelParameters(i).Name = tmp & i
Next i
Next i
End Sub
Now new problem was born. How can I rename model and reference params at one time?
I forgot abot it
Sorry
Message 9 of 19
Ralf_Krieg
Hello
Why did you write iLogic to your thread title if you ask VBA only?
Anyway, you can rename reference parameters the same way. You loop through the ReferenceParameter collection instead the ModelParameter collection. As a reference parameter can not have the same name as a model parameter, you can first start numbering of reference parameters at count of model parameters +1.
I'm getting sometimes an error 5 while renaming reference parameters.
Private Sub Rename()
    If Not ThisApplication.ActiveDocument.DocumentType = kPartDocumentObject Then
        Call MsgBox("This function is for part files only. Exit", VbMsgBoxStyle.vbCritical, "Rename model parameters")
        Exit Sub
    Dim s As String
    Dim i As Integer
    Dim j As Integer
    stmpString = "tmp"
    Dim sString As String
    sString = "d"
            oPartCompDef.Parameters.ModelParameters(i).Name = stmpString & CStr(i)
        Next i
            oPartCompDef.Parameters.ModelParameters(i).Name = sString & CStr(i)
        Next i
        For i = oPartCompDef.Parameters.ModelParameters.Count + 1 To oPartCompDef.Parameters.ModelParameters.Count + oPartCompDef.Parameters.ReferenceParameters.Count
            j = j + 1
            oPartCompDef.Parameters.ReferenceParameters(j).Name = stmpString & CStr(i)
        Next i
        oDoc.Update
        j = 0
            j = j + 1
            oPartCompDef.Parameters.ReferenceParameters(j).Name = sString & CStr(i)
        Next i
End Sub
R. Krieg
RKW Solutions
Message 10 of 19
bionorica2015
After i=100 an error occurs. In one part document when i=150 , in other i=100.(Call to undefined argument)
Message 11 of 19
bionorica2015
How can I skip error "Variable name is alraedy in use"?
When I have more than 1000 variables. I can not know is this variable name used in others.
Message 12 of 19
Ralf_Krieg
Hello
As I wrote in my last post, sometimes an Error 5 appears. I have no idea why, cause there is no visible reason to me. I tried different ways, but all failed. Sometimes the error disappeared when overwrite the failing parameter name by hand, sometimes that makes no difference.
In VBA the simpliest way is to use "On Error Resume Next" statement. This will ignore all errors and continue. You can check the Err.Number property to see if there was an error. Reset Error counter with Err.Clear and return to normal program behaviour with "On Error GoTo 0".
R. Krieg
RKW Solutions
Message 13 of 19
bionorica2015
Hello, Krieg!
Thanks a lot for Your code:
Option Explicit ON
Dim i As Integer
	Next i
	Next i
It works.
In the file which I am sending You now (file name: Detail_rename.ipt) error occurs and it fails.
Why it happens? What is solution in this case?
Thanks!
Message 14 of 19
Ralf_Krieg
Hello
As stated before, this is one of the errors that sometimes occur and I can't explain why. The parameter is correct renamed to a temporary name in first loop. Rename to the final name in second loop fails. You could try to catch this errors and display a message at end of program. After renaming the parameter manually to "d9" (in this case), running the rule again finishes without further error messages.
Wish I had a real solution, but did not found. 😞
Option Explicit ON
Dim i As Integer
Dim bErr As Boolean
	Try
		Next i
		Next i
	Catch ex As Exception
		bErr = True
	End Try
	If bErr Then
		MsgBox("Error occured, please check manually", MsgBoxStyle.Critical, "iLogic")
R. Krieg
RKW Solutions
Message 15 of 19
A.Acheson
This is still a mystery. Here is a work around, if you add a user parameter named as per the error bound model parameter then delete you can then rename the model parameter by code.
'Option Explicit ON
Dim i As Integer
Dim oDoc As PartDocument = ThisDoc.Document
	Dim oPartCompDef As SheetMetalComponentDefinition = oDoc.ComponentDefinition
	Try
			oPartCompDef.Parameters.ModelParameters(i).Name = "temp" & i.ToString
			Logger.Error( i & "-" & oPartCompDef.Parameters.ModelParameters(i).Name)
		Next i
		Catch
		MessageBox.Show("Error setting to temp", "Title")
	End Try
			Try
			Logger.Info(oPartCompDef.Parameters.ModelParameters(i).Name)
			Logger.Error(oPartCompDef.Parameters.ModelParameters(i).Name)
			Try
			Dim a As UserParameter = oPartCompDef.Parameters.UserParameters.AddByValue("d" & i.ToString, 1, UnitsTypeEnum.kUnitlessUnits)
			a.Delete
			Catch
				MessageBox.Show("Error doing work around", "Title")
			End Try
			Try
			Catch
				MessageBox.Show("Error setting Parameter", "Title")
			End Try
			End Try
		Next i
Regards
Alan
Message 16 of 19
WCrihfield
Hi @bionorica2015.  After opening your part and seeing what was going on with the parameter names, I can see that there are a couple of parameter names that seem to rename OK to the temporary name, but then do not want to rename back to a 'd' name.  So I simply incorporated a GoTo loop in there in a couple places, to make it try again with the next incremental integer, which then worked.  I generally do not recommend a scenario like that in more complex situations though, because it might lead to an endless loop.
Here is the code I wrote for this situation that seemed to work just fine, as far as I could tell.
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then
	MsgBox("A Part Document must be active for this rule to work. Exiting.", vbCritical, "")
	Exit Sub
Dim oPDoc As PartDocument = ThisDoc.Document
Dim oMPs As ModelParameters = oPDoc.ComponentDefinition.Parameters.ModelParameters
oTrans = ThisApplication.TransactionManager.StartTransaction(oPDoc, "Rename Parameters")
Dim i As Integer = 0
For Each oMP As ModelParameter In oMPs
	TryAgain1 :
	i = i + 1
	Dim oNewName As String = "tmp" & i
	Try
		oMP.Name = oNewName
	Catch
		Logger.Error("Failed to rename '" & oMP.Name & "' to '" & oNewName & "'")
		GoTo TryAgain1
	End Try
Next
oPDoc.Update
i = 0
	TryAgain2 :
	i = i + 1
	Dim oNewName As String = "d" & i
	Try
		oMP.Name = oNewName
	Catch
		GoTo TryAgain2
	End Try
Next
oPDoc.Update
oTrans.End
Wesley Crihfield
(Not an Autodesk Employee)
Message 17 of 19
bionorica2015
Thanks, but If You see my code is in VBA.
There is no try catch try again syntactic in vba.
How can we do that in vba?
Message 18 of 19
WCrihfield
OK.  Here is the VBA version.  I just commented out the 'Logger' lines, because they are iLogic only lines, and this is VBA.  I didn't think you would want to see a message box pop-up for each potential error if you may be processing a thousand parameters.  I suppose you could access the iLogic Add-In's automation resource from VBA, if you really wanted to, with some extra code, then gain access to its 'LogControl' object, but that seemed like too much extra code for now in this simple task.
Sub RenameAllModelParams()
    If ThisApplication.ActiveDocumentType <> kPartDocumentObject Then
        Call MsgBox("A Part Document must be active for this rule to work. Exiting.", vbCritical, "")
        Exit Sub
    Set oPDoc = ThisApplication.ActiveDocument
    Set oMPs = oPDoc.ComponentDefinition.Parameters.ModelParameters
    Dim oMP As ModelParameter
    Dim oTrans As Transaction
    Set oTrans = ThisApplication.TransactionManager.StartTransaction(oPDoc, "Rename Parameters")
    Dim i As Integer
    i = 0
    For Each oMP In oMPs
TryAgain1:
        i = i + 1
        oNewName = "tmp" & i
        oMP.Name = oNewName
        If Err <> 0 Then
            'Logger.Error ("Failed to rename '" & oMP.Name & "' to '" & oNewName & "'")
            GoTo TryAgain1
        On Error GoTo 0
    Next
    oPDoc.Update
    i = 0
TryAgain2:
        i = i + 1
        oNewName = "d" & i
        oMP.Name = oNewName
        If Err <> 0 Then
            GoTo TryAgain2
        On Error GoTo 0
    Next
    oPDoc.Update
    oTrans.End
End Sub
Wesley Crihfield
Message 19 of 19
cadman777
I'm a hacker at best, so not the guy to ask to write code for you.
Is it possible that the code is still seeing two Parameters of the same name?
Maybe you can rename all the parameters by adding any letter and number to the end of it so you can have infinite renames (instead of totally renaming each Parameter)?
@WCrihfield, @A.Acheson and @Ralf_Krieg have helped me in the past, and I learned this form some of the help they gave.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
