Drawing sketch - Attach text box to line end point
Caduser1FQQYS
Caduser1FQQYS
How do i attach this text to the line start/endpoint with ilogic.
Inserting it on that point works, but there is no link between both.
Sketched symbols are no option, and leader notes neither cause it has to be in a sketch.
dalton98
If you want the text to be inside of a sketch the sketch needs to be in edit mode. Hopefully this is what you were asking. Example:
Dim oDrawingDoc As DrawingDocument = ThisApplication.ActiveDocument
Dim oSheet As Sheet = oDrawingDoc.ActiveSheet
Dim oSketch As DrawingSketch = oSheet.Sketches.Item(1)
oSketch.Edit
Dim oPoint As Point2d
oPoint = oSketch.SketchLines.Item(1).StartSketchPoint.Geometry
Dim oTextBoxes As TextBoxes
oTextBoxes = oSketch.TextBoxes
oTextBoxes.AddFitted(oPoint, "hi")
oSketch.GeometricConstraints.AddCoincident(oSketch.SketchLines.Item(1).StartSketchPoint, oTextBox.OriginSketchPoint)
oSketch.ExitEdit
Caduser1FQQYS
This is exactly what I needed, thanks!
