Update to Sheet Metal Extents
ekinsb
Alumni Alumni
ekinsb
I just posted an update to the Sheet Metal Extents add-in on my blog. Please look here for more information.
http://modthemachine.typepad.com/my_weblog/2015/03/latest-update-to-sheet-metal-extents-add-in.html
Brian Ekins
Mod the Machine blog
skyngu
i hope there will be similar add-in with drawing view scale. neither ilogic nor prompt entry is good enough.
I like your sheet metal extents add-in. I have used it for few years. It works fine!
Autodesk Inventor Professional 2019
ekinsb
What specifically would you like to see with regards to drawing view scale?
Brian Ekins
skyngu
hi,
please check link below. you have listed two methods of adding drawing scale in title blocks. I wish there will be an addin similar with sheetmetal extents.
http://beinginventive.typepad.com/being-inventive/2013/03/adding-scale-to-title-block.html
thanks you very much!
MechMachineMan
My guess is that he would like the titleblock to automatically read the scale, rather than the user having to set it somehwere or use iLogic to accomplish the same thing. Also for use in sketched symbols.
Problems with his idea, however are:
What if the drawing view scales vary?
What if they are not to scale?
Which View does it pull the scale from?
These are easily manageable enough with some basic logic, but where places use different standards or not could complicate things - or mean there would be a Scale Standard as well in the Standards and Styles editor.
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
GeorgK
Hello Brian,
is it possible to get the source code for the addin?
Thank you Georg
