update the part number for all the parts in a assembly
joris81194
Observer Observer
joris81194
Observer
Observer
I copied a project with the use of ilogic design copy. That worked great. The new project now has the correct name.
Only when i look at the iproperties the part number is stil the same as the old project. And that number wil be displayed on the drawing. Is it posible to update all the part numbers for a assembly at ones?
Greetings Joris
A.Acheson
Hi @joris81194
Yes this will be possible. You would need to set up a comparison list maybe in excel and then loop through reference documents and properties accordingly. Have you examples of how the part numbers are changing? Here is an example of change all iproperties to that of the top assembly. Test in a sample assembly ...
Regards
Alan
joris81194
Observer
Observer
hi @A.Acheson,
If i use the code you send. The part number changes to the filename of the master assembly.
I want to change the partnumber to the filename of the part or of the subassembly.
joris81194
Observer
Observer
as you can see, the file name and the part number are different. and i wan the filename and the part numbers to match
A.Acheson
Hi @joris81194
You can pick up the filename using the System.IO.Path class see Microsoft help here.
Dim fileNameWOExt As String = IO.Path.GetFileNameWithoutExtension(oDoc.FullFileName)
In addition you will likely encounter errors if you have content center read only documents in the assembly and if you try to change those part numbers you will run into errors. So here is how to filter only Modifiable documents using document is Modifiable method
Syntax
Document.IsModifiable() As Boolean
If oDoc.IsModifiable Then
 ' Insert your iproperty code here.
Regards
Alan
