Derive value from a function
roberto_infanti
roberto_infanti
I have a solid.ipt (cubic for exsample). On one face, I apply an offset of 1 mm. on another 2mm, another 5mm, etc. I would like only faces that are offset by 5 to turn red. Thanks
JelteDeJong
This might work in some simple cases. But in more complex models it might fail. Give it a go.
Dim doc As PartDocument = ThisDoc.Document
Dim features = doc.ComponentDefinition.Features.ThickenFeatures
Dim asset As Asset = doc.Assets.Add(
			AssetTypeEnum.kAssetTypeAppearance,
			"Generic",
			"appearances")
Dim uColor As ColorAssetValue = asset.Item("generic_diffuse")
uColor.Value = ThisApplication.TransientObjects.CreateColor(255, 0, 0)
For Each item As ThickenFeature In features
	Dim distance = item.Distance.Value
	If (distance = 0.5) Then
		For Each outputFace As Face In item.Faces
			outputFace.Appearance = asset
		Next
Next
Jelte de Jong
Blog: hjalte.nl - github.com
roberto_infanti
Perfect!!!! Thankyou !!!!!  Just one question. Why is it that if I set inventor in mm and if the thicknen is equal to 5 mm, on the macro I am forced to write 0.5 (x/10) ?
JelteDeJong
Inventor uses what they call "Database" units. The "Database" unit for a length is "Cm". Therefore you need to divide by 10.
You can find more info in my blog post on that subject: "Parameter, Document and Database Units"
Jelte de Jong
roberto_infanti
Thanks, I get it. You're really kind! Thank you. I'll start reading your blog! You're really good. Congratulations
