Update the current date in drawing with iLogic
Hello
I am making a drawing, i is there a way to make a auto update od the date in titel block or text?
Yes
If (ThisDoc.Document.DocumentType <> kDrawingDocumentObject) Then Return
Dim odrawdoc As DrawingDocument
odrawdoc = ThisDoc.Document
If (odrawdoc Is Nothing) Then Return
customPropertySet=odrawdoc.PropertySets.Item("Inventor User Defined Properties")
iProperties.Value("Project", "Creation Date")=Now
InventorVb.DocumentUpdate()
thak ypu for your reply
can you tell me how can i use the rule
when i run it, nothing happens
rossano_praderi
Hi Aleksandar,
try this piece of code
If (ThisApplication.ActiveDocument.DocumentType = kDrawingDocumentObject Then
iProperties.Value("Project", "Creation Date") = Now.ToShortDateString()
iLogicVb.UpdateWhenDone = True
end if
Let me know if you have any troubles with it.
Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
edwin.davidU9BPU
oTime = Now.ToShortDateString
iProperties.Value("Project", "Creation Date") = oTime
