Define oDoc by Part name in Assembly
mk92
mk92
i cant find the way to define oDoc by the part name in an assembly.
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.Documents.ItemByName(ThisDoc.WorkspacePath()+"\Test.ipt")
I need this without the WorkspacePath.
Do you mean get the document from an occurence of a part in an assembly? Something like this:
Inventor.AssemblyDocument oAsemDoc = (Inventor.AssemblyDocument)oInvApp.ActiveDocument;
Inventor.ComponentOccurrence oCompOcc = oAsemDoc.ComponentDefinition.ActiveOccurrence; //or however you determine the part you are looking for
Inventor.PartDocument oInvDoc = oCompOcc.Definition.Document;
mk92
I need to do this:
Dim oCompDef As PartComponentDefinition
oCompDef = oPartDoc.ComponentDefinition
Dim oSketch As PlanarSketch
oSketch = oCompDef.Sketches.Item("Sketch1")
Without the WorkspacePath. I want to work with Sketch 1 from the part named Test.ipt.
Like:
oPartDoc = ThisApplication.Documents.ItemByName("Test:1")
So i want to use its Browser Name instead of its Path and Filename.
