Extrusion in an Assembly
mk92
Message 1 of 1
mk92
i want to check the active sketch for closed profiles and if there is one or more do an extrusion.
I found some code here: Link and tried to make it work in an assembly.
But the result is (in a sketch with 3 closed profiles) the message that there is no closed profile. Any ideas?
This is what i got:
If TypeOf ThisApplication.ActiveEditObject Is Sketch Then
'Do nothing
Else
MessageBox.Show("Activate a Sketch First then Run this Rule", "ilogic")
Return
Dim oAssDoc As AssemblyDocument
oAssDoc = ThisApplication.ActiveDocument
Dim oSketch As PlanarSketch
oSketch = ThisApplication.ActiveEditObject
' Create a profile.
Dim oProfile As Profile
On Error Goto NoProfile
oProfile = oSketch.Profiles.AddForSolid
Dim oExtrudeDef As ExtrudeDefinition
Dim ExtrudeDistance As Long
ExtrudeDistance = 20 mm
oDirection = kPositiveExtentDirection
oJoinOrCut = kJoinOperation
oExtrudeDef = oAssDoc.Features.ExtrudeFeatures.AddByDistanceExtent( _
oProfile, ExtrudeDistance, oDirection, oJoinOrCut)
ThisApplication.CommandManager.ControlDefinitions.Item("FinishSketch").Execute
iLogicVb.UpdateWhenDone = True
Exit Sub
NoProfile:
MessageBox.Show("No closed profile found", "iLogic")
Return
NoExtrude:
MessageBox.Show("No extrusion created, check your inputs.", "iLogic")
Return
Replies (0)
